8 3/4 into D150, shorten driveshaft?
#2244425
01/31/17 01:01 AM
01/31/17 01:01 AM
Posts: 781 usa
Mopar1970440
usa
8 3/4 rearend from a 67 pickup going into a 86 D150 2wd that currently has a 8 1/4. Will driveshaft shortening be needed? Thanks
Forgot to mention truck is an automatic/904 not a 727
Re: 8 3/4 into D150, shorten driveshaft?
[Re: Mopar1970440]
#2244807
01/31/17 05:13 PM
01/31/17 05:13 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The center-of-axle to center-of-u-joint dimension on the 8 1/4" is 11.69" and the 8 3/4" is 12.35" so you need to shorten the driveshaft .66".
[Re: Mopar1970440]
#2245104
02/01/17 01:54 AM
02/01/17 01:54 AM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
If it's a two piece shaft you may have enough room to slot the center bearing mount. When I converted my 92 diesel to lockup I did not have to shorten the shaft and that is a 1.125" difference.
[Re: Mopar1970440]
#2245355
02/01/17 04:06 PM
02/01/17 04:06 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I can remember someone on here years ago giving me a hard time cause I shorten mine up. Was basically saying I had no idea what I was saying....anyways....I had shorten mine up....been a long time now....don't remember how much....but....
Moparlee
[Re: Mopar1970440]
#2245585
02/01/17 10:40 PM
02/01/17 10:40 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
The intended use for the truck may also affect the clearance required.
I find the factory clearance to be more than generous. The factory ride height is pretty high too.
I had an 87 D100 and did the same 8 1/4 rear to 8 3/4 swap. Like Kunkel said, factory numbers require a slight trim but I did not shorten mine and had plenty of yoke to seal clearance. Even at a lowered ride height plus towing and overloading the bed the yoke only went forward another 1/8".
If you have clearance but the balloon seal is touching. They also have rear transmission seals without the balloon.
[Re: Mopar1970440]
#2246190
02/02/17 11:20 PM
02/02/17 11:20 PM
Posts: 15,487 Florida
scratchnfotraction
which has a longer shaft than a 727
what measurement do you get with yoke bottomed out in trans center of cap to center of cap?
the difference should still be what John said .66
I wager you need to chop off 1" that will get you off the seal lip and have room to slip.
[Re: Mopar1970440]
#2246625
02/03/17 05:07 PM
02/03/17 05:07 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
I went from a slant six/833od to a 440/727. same length. Put the 8 3/4 rear under it, and had to shorten driveshaft about 3/4" for it to be right. I run a driveshaft shop, so that wasn't an issue!
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
[Re: Mopar1970440]
#2249016
02/07/17 12:03 PM
02/07/17 12:03 PM
Posts: 781 usa
Mopar1970440
usa
I took the driveshaft to a machine shop to get 1" taken off and rebalanced if needed. I will install it tonight and see what happens and give an update. Thanks
UPDATE: The driveshaft bolted right it, everything looks good. ill finish a few small things (replace some wheel studs, bleed brakes) and hopefully the truck will be back on the road tonight and hopefully it pulls harder with these 3.91s, the 8 1/4 I replaced had 2.90s.
