Re: H wheel gloss level / A12 wheel lugs. [Re: bdgtfb] #2244341
01/30/17 11:28 PM
01/30/17 11:28 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I think they were rather glossy. Here is a 5-14-69 M5 wheel that was never installed and I was the first to have the mint redline removed. It was more glossy in person.
Re: H wheel gloss level / A12 wheel lugs. [Re: bdgtfb] #2244406
01/31/17 12:35 AM
01/31/17 12:35 AM
Mopar World Headquarters
P1970HeMICuDA Offline
They're gloss black, but the paint was a lower quality bought in bulk by the wheel company. The wheel paint didn't need to be of the same quality as the body paint- even lower quality for radiators,and other painted chassis parts. As far as I know, they were manufactured by Budd Wheels in Cambridge, Ont.
Re: H wheel gloss level / A12 wheel lugs. [Re: P1970HeMICuDA] #2244451
01/31/17 01:37 AM
01/31/17 01:37 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
M = manufacturer = Motor Wheel Corp. (a subsidiary of GOODYEAR Tire & Rubber)
5 = plant #5 = Chatham, Ontario, Canada (opened in '66, is it still there?)
how are we connecting that to Budd?
Re: H wheel gloss level / A12 wheel lugs. [Re: bdgtfb] #2244485
01/31/17 02:29 AM
01/31/17 02:29 AM
usa
bdgtfb Offline OP
bdgtfb  Offline OP
usa
does everyone agree with Big D A12 re the left hand thread wheel lug marking?
Re: H wheel gloss level / A12 wheel lugs. [Re: bdgtfb] #2244487
01/31/17 02:30 AM
01/31/17 02:30 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
yes, original LH lug nuts were stamped "L"
Re: H wheel gloss level / A12 wheel lugs. [Re: 6bblgt] #2244533
01/31/17 05:07 AM
01/31/17 05:07 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
And don't forget the "dimple" wink
Re: H wheel gloss level / A12 wheel lugs. [Re: P1970HeMICuDA] #2244565
01/31/17 10:31 AM
01/31/17 10:31 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
I think this is the best explanation I have heard. If you compare the gloss paints of today to the original bead area, there is a difference.
The semi gloss paints of today are a good match to the original finish, regardless of what it was called in 1969.
Good discussion guys. I think we have an answer? I will post a picture later today of the original lug nuts.
DD
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: H wheel gloss level / A12 wheel lugs. [Re: bdgtfb] #2244743
01/31/17 03:37 PM
01/31/17 03:37 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Now you do realize that HOW you spray the paint affects how it looks, right. Thin or thick paint aka amount of reducer, dry light spray or wet heavy coats, hot or cold day, hot or cold paint, humid or dry air, pressure at the gun, Etc.
Painting over bare metal makes the paint look a bit transparent. That is how wheels are painted. Try it at home sometime. Topcoat over primer or bare metal and see the results.
When was the body of a car painted over bare metal at the factory? Not at Chrysler, they were primered and sanded before paint.
Re: H wheel gloss level / A12 wheel lugs. [Re: NANKET] #2244996
01/31/17 10:55 PM
01/31/17 10:55 PM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
Exactly, I agree. Left hand lug nut below.
Re: H wheel gloss level / A12 wheel lugs. [Re: 6bblgt] #2245356
02/01/17 04:08 PM
02/01/17 04:08 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
http://www.chathamdailynews.ca/2011/04/03/fond-memories-of-motor-wheel
There were two of the same nuts like it is said above, one with no dimple the other has one. The dimple is what you want to be OEM. Use to have bags full of both threads, used to put them on everything that took a factory steel wheel.
1971 HEMI E BODY REGISTRY
Re: H wheel gloss level / A12 wheel lugs. [Re: Big D A12] #2245397
02/01/17 04:42 PM
02/01/17 04:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
& the "H" wheels were no different than any of the other typical steel wheels (the "cheapness" was across the board) - they were all painted gloss black by the wheel manufacturer
45+ year old "H" wheel between the beads scope
Dan - What plant is this wheel from? It does look more "glossy" than I am used to seeing. The H wheels on A12 cars originated at the M5 plant, so only those from that plant should be used for accurate reference.
Have you taken a tire off to compare the inside of the wheel to the outside of the wheel that has been exposed to varying degrees of UV for the last 40 years ?
Paint and how it was applied back in the 60's 70's is not the same as it is now.
I would flatten it so it looks somewhat close to it did back in the day ...
Re: H wheel gloss level / A12 wheel lugs. [Re: JohnRR] #2245632
02/01/17 11:45 PM
02/01/17 11:45 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
IMO the real reason the '69 A12 Road Runner's and Super Bee's came with 4-15"X6" black steel wheels and no hub caps and that you couldn't order other wheels.......so you didn't have to buy wheels to put your drag slicks of (2) different sizes (diameters) or different compounds. You could spend that money for narrower front rims and tires or a set of custom wheels to put the G-70/15 Goodyear red lines on for the street.
Mike
