So for the last 5-6 years my 78 powerwagon has had a strange electrical glitch. If I have my headlights on, heater fan on, and hit the brakes or turn signals it would kill the radio, and Id loose radio until I turned one ting off. I had always thought it was a radio feed issue and never really worried about it, well it has gotten worse and sometimes I would loose all power and it wouldn't crank over, If I tapped the brakes it would fire up. I was thinking a ground or something. Well my shop was empty for a change and I thought I need fix ol greenie.
First off I checked all my grounds, all seemed ok, I did need to replace the battery cause it got froze this winter. So I noticed that it seemed like a nw truck after that. So I checked the charging system. Mind you THis is a work truck I onlynuse if needed. Well damn its only charging at 12.8ish NOT GOOD right.
SO I start tracing wires, alternator seems fine, as its got 15ish at the alternator. So I contacted a buddy who is a lil more involved with the trucks than me. He told me to check amp gauge. I did that, they are tight, but he said chec connections, so I did. They didn't look horrible but I cleaned them anyways. I then also found a shady looking repair at the 2 wires that come off the starter relay. Factory fuseable link was blown from years ago and My Dad had repaired it, but the repair was full of corrosion, I cut it all out, soldered and heat shrinked the connection, and then I checked it again.
WELL!!! Its charging at 14.2 no load, and 13.8-14 under full load. Truck runs better, radio is golden, lights are brighter, truck starts better, just all around better!!!
Now I actually want to drive it more! No issues of it dying on me now.
SO now Im looking for BIG BLOCK parts for Ol Greenie!!
