Re: overheating problem on 440 motor
[Re: F6F6Dodge]
#224401
02/14/09 01:22 PM
02/14/09 01:22 PM
RapidRobert
Not enough airflow. I'm assuming timing/mixture is close enough. I'd try it without the pusher & have the clutch fan blades partly into the shroud. 160 of a stat is too cold but I'd leave it alone until you fix this (unrelated to the 160 stat) issue.
[Re: F6F6Dodge]
#224408
02/14/09 03:09 PM
02/14/09 03:09 PM
RapidRobert
You might go to a radiator shop & have them pump it up to 15lbs(when hot) & see if it holds & also them to suck some air thats above the coolant level up into the blue fluid with their kit & see if it changes color indicating a combustion leak. Shouldn't take too much time/money & it'd be far easier than tearing into the eng. But if your timing is not retarded it sounds from your last description that there "might" be something off kilter inside the eng but I'd for sure eliminate the airflow possibility & the stat 1st. What do your plugs look like. I'd say an improperly punched head gasket would be much less likely
