80 or 130? #2243940
01/30/17 02:07 PM
01/30/17 02:07 PM
California
mickm Offline OP
mickm  Offline OP
California
I'm putting a new spindle on the car, and the two lower bolts, the bigger ones, that tie the brake backing plate to the spindle, and then the lower ball joint, call for 100 ft/lbs. unfortunately, the castle on the nut exactly covers the cotter key hole at 100. if I back it off to the previous slot, it sits at 80 ft/lbs. if I take it to the next one, it's easily 130 ft/lbs, maybe a little more.
which way should I go?
Re: 80 or 130? [Re: mickm] #2243944
01/30/17 02:13 PM
01/30/17 02:13 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
I'd try removing the castle nut and cleaning the threads on the inside as well as I could and also the bolt threads that attach to the backing plate and re-torqueing. Try tracing these with the proper tap and die to get them cleaned out. I would not go 80 ft/Ibs.
Re: 80 or 130? [Re: L.R Helbling] #2243962
01/30/17 02:49 PM
01/30/17 02:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Most people do not have the proper tap and die to do that work. That is why I suggest you NEVER use a tap and a die to clean threads on both sides of an existing fastener. Many times it will lead to a sloppy fit and weaker joint.
Taps and dies both come in different fits. They are sized for different applications and classification of thread fit.
If you get taps and dies that are mismatched by a fair percentage you can get a fastener combination that is downright dangerous. With Harbor Freight junk there is no telling if the tools are even built to a recognized standard.
If the only way you have to clean a thread is with a hardware store tap and die set then only do the nut or the bolt. Never do both. At that point you need to replace one or both fasteners.
- Stu Harmon
Re: 80 or 130? [Re: L.R Helbling] #2243963
01/30/17 02:49 PM
01/30/17 02:49 PM
California
mickm Offline OP
mickm  Offline OP
California
I didn't tap them, but I did clean well. not sure if that was enough. it sounds like you are saying that they are designed to align right at 100 ft/lbs?
Re: 80 or 130? [Re: mickm] #2243968
01/30/17 02:55 PM
01/30/17 02:55 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
No, they are not designed to align at 100 lb/ft. The individual parts are mass produced, not a matched set.
With 8 slots to chose from there's a pretty good chance it will align at 100 lb/ft the first time out but it isn't guaranteed.
Ball joints are machined tapers designed to lock together through a proper fit. The nut is there to pull them together properly and is left in place as added insurance. After all, they won't hold together under all circumstances.
130 lb/ft won't hurt the fastener. That size thread will take far more torque.
- Stu Harmon
Re: 80 or 130? [Re: mickm] #2243973
01/30/17 03:05 PM
01/30/17 03:05 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
These are the bolts and nuts the go through the spindle and lower ball joint, not the tapered stud of the ball joint. Different thickness of the 3 parts joining together is the deal here. Make sure no dirt or grease between all mating surfaces and tighter is better with lubed threads.
Re: 80 or 130? [Re: NANKET] #2243985
01/30/17 03:14 PM
01/30/17 03:14 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
OOPS.
Still, they are not matched pairs. No worries about going 130 lb/ft on those.
5/8-18 grade 5 bolts are rated for 128 lb/ft and grade 8 are rated at 180 lb/ft.
I don't recall the rating on those bolts but I can't picture them using a cheese grade bolt in there.
- Stu Harmon
Re: 80 or 130? [Re: mickm] #2243992
01/30/17 03:30 PM
01/30/17 03:30 PM
Ottawa, Ontario
Ottawa, Ontario
If they're cleaned well enough then you needn't try tracing them with a die large enough to go over your bolt. That suggestion was just meant to see if your bolt or nut was damaged because it would simply stop and bind. Try spinning your castle nut from different positions to see if it grabs early or late. It might not go much past 100 ft/ Ibs. All surfaces must be cleaned as Nantucket says.
Re: 80 or 130? [Re: L.R Helbling] #2243999
01/30/17 03:38 PM
01/30/17 03:38 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Common nuts and bolts have single start threads. They will only start in one position.
Milk bottles, soda bottles, and things that need to move large distances with few turns use 2, 3, or 4 start threads where you can clock them and try another starting position.
- Stu Harmon
Re: 80 or 130? [Re: mickm] #2244039
01/30/17 04:28 PM
01/30/17 04:28 PM
Ottawa, Ontario
Ottawa, Ontario
Well, from what I've seen here, and from the posts that I've read, the OP doesn't really have much of a problem. If these are 5/8-18 bolts grade 5 bolts and they are truly rated for 128 ft/Ibs and 130 ft/Ibs is not too much, then torque to that value.
If not, then I've only got one other suggestion and that is to use a different castle nut on the same bolt to see if that will grab from a different position and lock in at about 100 Ft/Ibs. Bolts and nuts can be subject to stress and maybe one of the 2 has been subject to more stress than the other.
The only reason I weighed in is because I experienced the same problem with my set up going from power front drums to power front discs. I ended up resolving it by trying a different castle nut after ensuring that everything was clean and straight.
Re: 80 or 130? [Re: L.R Helbling] #2244185
01/30/17 08:11 PM
01/30/17 08:11 PM
Might be overkill but you could drill another roll pin hole in the threads at that end. The nut will be further on than the hole(s) locations so integrity wont be compromised.
Re: 80 or 130? [Re: mickm] #2244209
01/30/17 08:40 PM
01/30/17 08:40 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I personally wouldn't drill another hole. As Feets mentioned, the bolt should handle the slightly higher torque. If you didn't want to do that, other option to me would be to use a hardened washer until the nut to help line up the slot under the correct tension.
Re: 80 or 130? [Re: OzHemi] #2244213
01/30/17 08:49 PM
01/30/17 08:49 PM
PA
70Duster Offline
70Duster  Offline
PA
Don't over think this. On castle nuts, you go to the recommended torque and then a little more if necessary to get the pin through the hole. Never go backwards. In this case, go to 130 ft-lbs and be done.
Re: 80 or 130? [Re: mickm] #2244237
01/30/17 09:16 PM
01/30/17 09:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
100 ft/lbs is the minimum torque.....it's assumed that the hole won't line up so you're expected to tighten (never loosen) the nut until the hole lines up.
Re: 80 or 130? [Re: John_Kunkel] #2244241
01/30/17 09:22 PM
01/30/17 09:22 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Of course you could always buy new grade 8 bolts and self locking nuts or use Red locktite on the nuts. 3M weatherstrip adhesive on the bolt threads will ensure they don't vibrate loose, too...but what do I know?
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 80 or 130? [Re: Polarapete] #2244299
01/30/17 10:31 PM
01/30/17 10:31 PM
California
mickm Offline OP
mickm  Offline OP
California
thanks for the replies everyone, learned a lot form this.
took the nuts off, cleaned them again, put the tiniest bit of lube on them, and switched them. first one went on the same way, hole completely covered, so just kept cranking until it was clear. second one went on and the hole was nice and open at 100 ft/lbs.
done!
Re: 80 or 130? [Re: mickm] #2244336
01/30/17 11:21 PM
01/30/17 11:21 PM
done!
That was too easy!
Re: 80 or 130? [Re: mickm] #2244364
01/30/17 11:48 PM
01/30/17 11:48 PM
Ottawa, Ontario
Ottawa, Ontario
That's how I did mine.
Re: 80 or 130? [Re: mickm] #2244381
01/30/17 11:59 PM
01/30/17 11:59 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
You can also use a thin washer. This results in a slightly different position of the castle nut.
Re: 80 or 130? [Re: Jjs72D] #2244386
01/31/17 12:04 AM
01/31/17 12:04 AM
Ding ding ding I do believe we have a winna.
