Has my balancer slip. #2243874
01/30/17 11:46 AM
01/30/17 11:46 AM
Canada
Dons Dart Offline OP
Canada
86 360 with the comp cam # 20 222-3,the engine is still on the stand.My worries is did the well know engine builder in my area goof the degree my cam or has the balance r slip.When i line it up at dot to dot with piston at # 1 the line on my balance r does not line up with 0 its more like 8atdc,hes says its set at 105 center line,also he said to get the specs right he had to use a 3 degree off sat key in the cam.
Re: Has my balancer slip. [Re: Dons Dart] #2243876
01/30/17 11:51 AM
01/30/17 11:51 AM
Indiana
EV2DEMON Offline
The Camaro Kid
EV2DEMON  Offline
The Camaro Kid
Indiana
Cam position has nothing to do with balancer/TDC relationship.
Are you using a piston stop and rotating both directions to find TDC? What kind of pointer do you have?
Re: Has my balancer slip. [Re: EV2DEMON] #2243881
01/30/17 12:02 PM
01/30/17 12:02 PM
Canada
Canada
Just going by eye no stop.
Re: Has my balancer slip. [Re: Dons Dart] #2243898
01/30/17 12:36 PM
01/30/17 12:36 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Verify TDC and check balancer.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Has my balancer slip. [Re: Dons Dart] #2243902
01/30/17 12:44 PM
01/30/17 12:44 PM
balancer slipping is rare but does happen. As said it wouldn't hurt to get the cheap piston stop tool and check if the dampener slit is at TDC when the piston is at TDC but to keep it simple sam I would start with, are you looking at the right "mark" some of the aftermarket combos of dots/ovals/triangles/squares are confusing as they can be very similar & the ones closest to the keyway are to tell you which slot to use and the ones up by the teeth are the actual "dot" to use to get to "dot to dot". that cam has a 110 LSA and a 106 ICL. And 103 is 3 degrees advanced from 106. With more thought right now I think I would set the dampener at 10 before then hand bump the slot forward to TDC then see where the dots are at & get back to us. another thought, with the dots where they are at, are you then installing the t cover & dampener?
Re: Has my balancer slip. [Re: Dons Dart] #2243925
01/30/17 01:44 PM
01/30/17 01:44 PM
Washington
madscientist Offline
Washington
You don't degree the cam with the balancer.
Verify TDC with a positive stop.
TDC verification should have been done when the engine was assembled and correct at that point if it was wrong. That is the job of the assembler.
I've seen many balances have the outer turn on the inner hub. It's not rare and all brands of engines suffer from it when using and OE or OE type damper.
Re: Has my balancer slip. [Re: RapidRobert] #2243974
01/30/17 03:06 PM
01/30/17 03:06 PM
Canada
Canada
yes its what i notice when i was installing the timeing chain cover.
Re: Has my balancer slip. [Re: Dons Dart] #2243984
01/30/17 03:13 PM
01/30/17 03:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Cam timing is not done with timing marks on the damper. It's done with degree wheels and dial indicators. Damper to timing tab TDC is a basic check when assembling an engine. "Eyeballing" any of it won't work.
Re: Has my balancer slip. [Re: CMcAllister] #2244030
01/30/17 04:10 PM
01/30/17 04:10 PM
Canada
Canada
Ok got it,as said i did not do the degree it was done at the machins shop.I guess it was done right.just chacking.
Re: Has my balancer slip. [Re: Dons Dart] #2244038
01/30/17 04:27 PM
01/30/17 04:27 PM
Many general machine shops do not verify TDC on the balancers and some of them ASSUME that when they use the 4 degree advance slots on the crank gears that he cams are advanced 4 degrees instead of taking the time to VERIFY the cam timing in relation to TDC tsk shruggy
Re: Has my balancer slip. [Re: RapidRobert] #2244095
01/30/17 05:51 PM
01/30/17 05:51 PM
organ
maximum entropy Offline
organ
consider yourself lucky. i see it all the time. occasionally on new ones, even. always check.
Re: Has my balancer slip. [Re: Dons Dart] #2244274
01/30/17 10:08 PM
01/30/17 10:08 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
I've had it happen twice and I'm only 32. Once on a big block Mopar and once on a small block Ford; the Ford balancer was removed in two pieces it was so bad.
Re: Has my balancer slip. [Re: parksr5] #2244378
01/30/17 11:55 PM
01/30/17 11:55 PM
Don keep us updated on how it turns out.
Re: Has my balancer slip. [Re: RapidRobert] #2244581
01/31/17 11:19 AM
01/31/17 11:19 AM
Canada
Canada
Yes will do,its very cold now winter wont know how it runs till late spring.
