wheel spin
#224321
02/14/09 10:43 AM
02/14/09 10:43 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
hi heads, indy 360-1 cnc flow343 @ 600 intake 225 ex @600 ,indy intake,750 bg , t d 1.6 rollors. 410 cube ,11.8 comp ,259/265 @ 050 109 l/c 3 degee advance .200 figures are 176 in 171 ex solid flat tappet 3300 stall 904 , 3.9 gears 26/10/15 slicks 3550 lbs. done a couple changers,an raced her today ,they where 840 pro systems carbie , 4900. split mono leaf .caltracs are set top hole 0 pre load 50/50 rear shocks, 25 psi tyre pressure.1 pass 2.20 60 ft ,97 mph @8.02 spun 3/4 track .2 pass 20 psi 1.8 60 ft 7.48 @ 100 mph , spinning hard first an second . cabie and converter made it come to life . 3550 @ 100 mph is close to 590 hp . all help welcome.
Re: wheel spin
[Re: Ian]
#224322
02/14/09 10:49 AM
02/14/09 10:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You could move the cam back to 0 to pull some of the torque out down low and give you a better run on the top end.... or you could just put in a programmable 7 MSD box to add timing in after the launch
Re: wheel spin
[Re: topside]
#224325
02/14/09 01:46 PM
02/14/09 01:46 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Slicks at 25PSI ???
What he said... Id start around 14 lbs and go down from there if they are slicks...
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: wheel spin
[Re: Ian]
#224327
02/14/09 05:52 PM
02/14/09 05:52 PM
MR_P_BODY
Like the others have said... lower your tire pressure and also stiffen up the shock(extension). Take a video of your launch... you'll learn alot from the video
Re: wheel spin
[Re: MR_P_BODY]
#224328
02/14/09 06:06 PM
02/14/09 06:06 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Yep, tire pressure! Compression is low for that intake port, and cam will not really "use" that head the best it can!! You have alot left on the table for sure. Brian
Brian Hafliger
