wheel spin #224321
02/14/09 10:43 AM
02/14/09 10:43 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
hi heads, indy 360-1 cnc flow343 @ 600 intake 225 ex @600 ,indy intake,750 bg , t d 1.6 rollors. 410 cube ,11.8 comp ,259/265 @ 050 109 l/c 3 degee advance .200 figures are 176 in 171 ex solid flat tappet 3300 stall 904 , 3.9 gears 26/10/15 slicks 3550 lbs. done a couple changers,an raced her today ,they where 840 pro systems carbie , 4900. split mono leaf .caltracs are set top hole 0 pre load 50/50 rear shocks, 25 psi tyre pressure.1 pass 2.20 60 ft ,97 mph @8.02 spun 3/4 track .2 pass 20 psi 1.8 60 ft 7.48 @ 100 mph , spinning hard first an second . cabie and converter made it come to life . 3550 @ 100 mph is close to 590 hp . all help welcome.
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: wheel spin [Re: Ian] #224322
02/14/09 10:49 AM
02/14/09 10:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You could move the cam back to 0 to pull some of the
torque out down low and give you a better run on the
top end.... or you could just put in a programmable
7 MSD box to add timing in after the launch
Re: wheel spin [Re: Ian] #224323
02/14/09 11:02 AM
02/14/09 11:02 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
b 4 i made the changes the cam was retared and it ran 7.6 at 95 mph car has ran 6.7 @103 with 150 nos j heads 10.1 comp , ryan j is helping me with the combo works a lot better than it did.
Re: wheel spin [Re: Ian] #224324
02/14/09 01:41 PM
02/14/09 01:41 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Slicks at 25PSI ???
Re: wheel spin [Re: topside] #224325
02/14/09 01:46 PM
02/14/09 01:46 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Slicks at 25PSI ???
What he said... Id start around 14 lbs and go down from there if they are slicks...
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: wheel spin [Re: topfueldart] #224326
02/14/09 05:43 PM
02/14/09 05:43 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Dont know what tire you have on the rear, but 25 psi is high for a slick.If you have a slick on lower it and if that dont work put the Cal Tracs in the lower hole and preload them.Good luck
Re: wheel spin [Re: Ian] #224327
02/14/09 05:52 PM
02/14/09 05:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Like the others have said... lower your tire pressure
and also stiffen up the shock(extension). Take a
video of your launch... you'll learn alot from the video
Re: wheel spin [Re: MR_P_BODY] #224328
02/14/09 06:06 PM
02/14/09 06:06 PM
SoCal
Brian Hafliger Offline
SoCal
Yep, tire pressure! Compression is low for that intake port, and cam will not really "use" that head the best it can!!
You have alot left on the table for sure.
Brian
Brian Hafliger
Re: wheel spin [Re: Brian Hafliger] #224329
02/14/09 07:11 PM
02/14/09 07:11 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
tyres are 255/60/15 drag radial , which holes loads the tyres ? more i have 2 hole at diff an 2 holes at frount plate and i ran them in lower hole at diff an top hole frount.
Re: wheel spin [Re: Ian] #224330
02/15/09 03:02 AM
02/15/09 03:02 AM
Put the front end one down and try that, every car and track like different combinations, keep testing to get hte best results and the most knowledge (expereince) from the testing
Re: wheel spin [Re: Cab_Burge] #224331
02/15/09 06:13 AM
02/15/09 06:13 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
i will give that a try thanks. any other tips?
