Panel bonding a roof skin
#2242542
01/27/17 11:37 PM
01/27/17 11:37 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I'm fixin to replace the roof skin on my GTS and I am considering using a panel bonding agent on the side. I would still weld the window areas and at the quarter and A-pillar joints. My brother has done it on several cars with success but I would like to hear from others that have used it for the best brand and any pitfalls or dos and don'ts.
Thanks in advance, Kevin
Careful, your character's showing!
Re: Panel bonding a roof skin
[Re: mopar346]
#2242746
01/28/17 12:59 PM
01/28/17 12:59 PM
mopar346
Prep is actually one of my questions, if you prep and paint the metal with the coating of your choice are you then counting on the coating and not the bonding agent? I am told the bonding agent works as a primer sealer so paint is not necessary between the panels which makes sense.
[Re: mopar346]
#2242750
01/28/17 01:10 PM
01/28/17 01:10 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
we use 3M 3-1 mix panel bonding adhesive at the body shop where i work. i am not sure of the part #. you will need a special applicator gun to use it.
when i bond a roof i will triple check fitment before bonding. proper panel fitment between the panels is important. if the adhesive area is to thick bond separation can happen. once i am happy with fit i will drill a few alignment holes to make sure it's bonded in the same place i was happy with. before applying adhesive grind all of the bond area with 36 grit and blow away any dirt or dust. dust or dirt in the adhesive will weaken the bond. apply the adhesive over the all of the exposed bare metal on both sides of the bond. i use a acid brush to spread the adhesive. when clamping don't over tighten the clamps, just tighten the vice grips lightly snug. over tightening the clamp will leave to thin bond area and can lead to bond separation. you should clamp the bond every 6"-8" and leave them clamped according to instructions. i don't remember clamp time but i do believe cure time on 3M adhesive is 24 hours. the METAL MUST BE AT RECOMMENDED TEMP FOR THE ENTIRE CURE TIME. use this formula for cure times. 15* WARMER cuts cure time in 1/2, 15* COLDER DOUBLES cure time. hope this info helps.
perception is 90% of reality
[Re: mopar346]
#2242752
01/28/17 01:13 PM
01/28/17 01:13 PM
Mr T2U
Prep is actually one of my questions, if you prep and paint the metal with the coating of your choice are you then counting on the coating and not the bonding agent? I am told the bonding agent works as a primer sealer so paint is not necessary between the panels which makes sense. their shouldn't be any coatings on the metal in the bond area. the bond area should be bare metal lightly ground with a 36 grit disc. the 36 grit leaves a tooth for the adhesive to grip to. there are rust inhibitors in the adhesive.
[Re: mopar346]
#2242754
01/28/17 01:15 PM
01/28/17 01:15 PM
mopar346
Exactly what I was looking for, so I take it you would have no concerns about bonding the roof on one of our cars.
[Re: mopar346]
#2242988
01/28/17 07:58 PM
01/28/17 07:58 PM
Mr T2U
one thing to keep in mind. body filler doesn't like to stick to the adhesive. you must clean the joint seam as best as possible, then epoxy it. make sure the epoxy is fully cured, PPG DPLF epoxy primer doesn't fully cure for 7 days, then scuff and apply filler.
