Page 11 of 17 1 2 9 10 11 12 13 16 17
Re: Challanger Demon [Re: MR_P_BODY] #2242253
01/27/17 02:01 PM
01/27/17 02:01 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Watching the last vid with smoke shooting out from under back of car...does that not remind you of open headers or cutouts/dumps of some sort?
The exhaust tips are at the corners of the rear of car. That's is deff is not what is blowing the smoke back.....watch the vid and give your thoughts on this please
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Challanger Demon [Re: MR_P_BODY] #2242260
01/27/17 02:09 PM
01/27/17 02:09 PM
Home
SRT6776 Offline
I hate internal combustion engines!
SRT6776  Offline
Home
And about the weight loss. IIRC the Maserati Ghibli and Quattroporte also use the same platform, but use aluminum and other light weight materials where the Dodge's use stamped steel. So they may have raided the Maserati parts bin to shave a few pounds if these are actual interchangeable chassis items.
Re: Challanger Demon [Re: toplescuda] #2242292
01/27/17 03:10 PM
01/27/17 03:10 PM
Outside
thedriver Offline
thedriver  Offline
Outside
My first thought was it has exhaust relocated to the center under the licence plate...
1973 challenger
Dana. 4 speed. Low deck.
Re: Challanger Demon [Re: MR_P_BODY] #2242335
01/27/17 04:26 PM
01/27/17 04:26 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
That's not where the exhaust tips are at
You can see them closer to the corners of the car. Where the smoke is blowing straight out near the center
1971 charger
Re: Challanger Demon [Re: toplescuda] #2242415
01/27/17 07:12 PM
01/27/17 07:12 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Originally Posted By toplescuda
I think that is the best guess also
Wrong, laugh2 and I,ll tell you why. The 2576 is the number of cc,s of the blower. The fact that, that number would be on the plate Just by Chance, would be almost 14,000,000 to 1
Now the suggestion that it may be the weight difference of the car compared to the hellcat, and the fact that that number also, Just happens to match the cc,s of the new blower, Not possible IMO. devil laugh2
But, I really don't know 100% maybe 80%, wouldn't bet my life on it though. up grin
Re: Challanger Demon [Re: MR_P_BODY] #2242420
01/27/17 07:24 PM
01/27/17 07:24 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The smoke is tire smoke getting blown back by the exhaust. See it a million times at the drags.
Re: Challanger Demon [Re: Sport440] #2242422
01/27/17 07:31 PM
01/27/17 07:31 PM
The NB Vermont
dustaboy74 Offline
dustaboy74  Offline
The NB Vermont
I read one one site and what sounded like the best guess was that the #2576 stood for lbs and the 35 was psi and was directly correlated with the tires. The load rating of 2576lbs at 35 psi air pressure. This is high considering the current drag radial nittos are ~1900lbs max load rating.
This sounded right since each of the videos they have put out have dealt directly with one aspect of the car (first video was weight, this newest video is tires).
Re: Challanger Demon [Re: dustaboy74] #2242457
01/27/17 08:58 PM
01/27/17 08:58 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Can anyone say if they changed the coil pack for the Demon?
I know the 6.2 Hellcat uses the same coil as the 6.1 and 6.4.
IF the blower is pushing 35psi I would think they needed to upgrade the coil.
Hemiup found this out will pushing 28 PSI through a 6.1. IIRC
Matt
Re: Challanger Demon [Re: MR_P_BODY] #2242462
01/27/17 09:08 PM
01/27/17 09:08 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
The blower is not pushing 35 pounds. Heck it not pushing 25 pounds lol
1971 charger
Re: Challanger Demon [Re: toplescuda] #2242477
01/27/17 09:35 PM
01/27/17 09:35 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Thats what I'm thinking.
Someone awhile back mentioned the original Hellcat engine was capable of much more. In fact they had to de tune it twice because the powers to be thought is was too much HP and didn't want to overshadow the flagship VIPER.
Don't know how much truth is to it.
Matt
Re: Challanger Demon [Re: MR_P_BODY] #2242535
01/27/17 11:28 PM
01/27/17 11:28 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
If they had a blower that could push 35 psi it would have about 2000 hp
Re: Challanger Demon [Re: MR_P_BODY] #2242625
01/28/17 02:04 AM
01/28/17 02:04 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Missing a golden opportunity here.....
Put a beefier AWD chassis under it, weight would not matter eiththat kind of power AND AWD traction
WIZE
In Car:
Re: Challanger Demon [Re: dustaboy74] #2242662
01/28/17 04:53 AM
01/28/17 04:53 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Ok, that could be it. But what a Boring Spec, Why would they advertise that. Most people don't know if that's impressive or not. I certainly wouldn't put That spec on a License plate to impress anyone.
My New truck tires are rated at #3250 @ 45 PSI, Sweet, the New Demon Hellcat, sucks compared to my tires Specs.
I Need a Friggen New license plate.
See, That Cant be it. drive shruggy
Re: Challanger Demon [Re: MR_P_BODY] #2243323
01/29/17 12:58 PM
01/29/17 12:58 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I know nothing about Twitter but isn't the # a 'hashtag'?
Maybe thereis a clue there?
WIZE
In Car:
Re: Challanger Demon [Re: MR_P_BODY] #2244841
01/31/17 06:18 PM
01/31/17 06:18 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
Re: Challanger Demon [Re: MR_P_BODY] #2244957
01/31/17 10:04 PM
01/31/17 10:04 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Some info
1971 charger
Re: Challanger Demon [Re: MR_P_BODY] #2245223
02/01/17 12:30 PM
02/01/17 12:30 PM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
New write-up claims there's only one seat in it to save weight...
https://www.carthrottle.com/post/the-dodge-challenger-demon-will-only-have-one-seat-to-save-weight/
Re: Challanger Demon [Re: MR_P_BODY] #2245415
02/01/17 05:31 PM
02/01/17 05:31 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Will be option if ya want it
1971 charger
Re: Challanger Demon [Re: toplescuda] #2245424
02/01/17 05:51 PM
02/01/17 05:51 PM
Kirkland, Washington
Pacnorthcuda Offline
Uncharted territory. Anyone know what the air-bag configuration is???
Re: Challanger Demon [Re: MR_P_BODY] #2245433
02/01/17 06:10 PM
02/01/17 06:10 PM
Home
SRT6776 Offline
SRT6776  Offline
Home
I think they are deliberately putting disinformation out there about the two cars twocents
