Teflon or Rubber Stainless Hose? #224139
02/14/09 01:38 AM
02/14/09 01:38 AM
Alexandria, VA
SealockRacing Offline OP
Alexandria, VA
so, local hydraulic shop can get me any an fittings i need, and how ever much hose i want, either kind.
they said they reccomend the teflon for all uses, only thing is, you cant bend it too much... other than that, they said it will last forever.
what do you guys think?
John
Re: Teflon or Rubber Stainless Hose? [Re: SealockRacing] #224140
02/14/09 02:02 AM
02/14/09 02:02 AM
AndyF Online content
AndyF  Online Content
What are you using it for? Teflon is used for brake lines and other places where the pressure is high or the fluid is nasty.
Re: Teflon or Rubber Stainless Hose? [Re: SealockRacing] #224141
02/14/09 03:14 AM
02/14/09 03:14 AM
I use Teflon lined stainless hose wherever I can, temperature and burst strength is way better than neopreme
Re: Teflon or Rubber Stainless Hose? [Re: SealockRacing] #224142
02/14/09 03:59 AM
02/14/09 03:59 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Teflon if you can afford it.
Re: Teflon or Rubber Stainless Hose? [Re: SealockRacing] #224143
02/14/09 03:48 PM
02/14/09 03:48 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
Check out Icore stainless hose.
It is made with a convoluted teflon liner and is the most flexable hose on the market. Very light weight. Used by many Cup teams.
www.bmrs.net
Re: Teflon or Rubber Stainless Hose? [Re: ToddP] #224144
02/14/09 09:36 PM
02/14/09 09:36 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
www.bmrs.net
I use the BMRS Progold stuff for my main fuel line. Awesome stuff but not necessarily inexpensive. Goodridge has a similar product.
One of my friends was amazed at how light and flexible it is. Just don't step on or pinch it.
Re: Teflon or Rubber Stainless Hose? [Re: RobX4406] #224145
02/15/09 02:03 AM
02/15/09 02:03 AM
Alexandria, VA
Alexandria, VA
okay cool, cause im pretty sure that i will re hose the entire car within the next year, this shop can get me 20ft of the teflon for 70 bucks or so, and ill just reuse the fittings that are on there.
i figure itll cost less thant 300 bucks to re do the fuel lines throughout the car, along with doing the cooler lines, and maybe a new oil press. line.
so you guys would go with the teflon stuff?
Re: Teflon or Rubber Stainless Hose? [Re: AndyF] #224146
02/15/09 02:06 AM
02/15/09 02:06 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I used teflon on the oil pressure that comes into the car.Just incase
Re: Teflon or Rubber Stainless Hose? [Re: SealockRacing] #224147
02/15/09 02:21 AM
02/15/09 02:21 AM
RobX4406 Offline
RobX4406  Offline
Teflon hose uses fitting that are different from the standard rubber steel braided line. Has an olive/ferrule that goes between the braid and teflon liner. If you go teflon from std hose, you'll be buying all new hose ends.
The AN to pipe adapters should be the same 37* flare.
Re: Teflon or Rubber Stainless Hose? [Re: SealockRacing] #224148
02/15/09 03:21 AM
02/15/09 03:21 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The Teflon stuff is nice, but out of my price range. The high end teflon lines are very flexable, and handle much higher pressures, but require the special crimp on ends, and I think some of that line is over $40/foot?
Re: Teflon or Rubber Stainless Hose? [Re: SealockRacing] #224149
02/15/09 10:41 AM
02/15/09 10:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you want to look for a good hose, look for a hose
that has a Viton liner, Viton is impervious to most
anything that you would run through it. Its just a
thin liner and you can use the regular fittings
