Re: Teflon or Rubber Stainless Hose?
[Re: SealockRacing]
#224143
02/14/09 03:48 PM
02/14/09 03:48 PM
Posts: 684 Milwaukee
ToddP
super street
super street
Milwaukee
Check out Icore stainless hose. It is made with a convoluted teflon liner and is the most flexable hose on the market. Very light weight. Used by many Cup teams. www.bmrs.net
[Re: ToddP]
#224144
02/14/09 09:36 PM
02/14/09 09:36 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
I use the BMRS Progold stuff for my main fuel line. Awesome stuff but not necessarily inexpensive. Goodridge has a similar product.
One of my friends was amazed at how light and flexible it is. Just don't step on or pinch it.
[Re: AndyF]
#224146
02/15/09 02:06 AM
02/15/09 02:06 AM
Posts: 28,611 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
What are you using it for? Teflon is used for brake lines and other places where the pressure is high or the fluid is nasty.
I used teflon on the oil pressure that comes into the car.Just incase
[Re: SealockRacing]
#224147
02/15/09 02:21 AM
02/15/09 02:21 AM
RobX4406
okay cool, cause im pretty sure that i will re hose the entire car within the next year, this shop can get me 20ft of the teflon for 70 bucks or so, and ill just reuse the fittings that are on there.
i figure itll cost less thant 300 bucks to re do the fuel lines throughout the car, along with doing the cooler lines, and maybe a new oil press. line.
so you guys would go with the teflon stuff?
Teflon hose uses fitting that are different from the standard rubber steel braided line. Has an olive/ferrule that goes between the braid and teflon liner. If you go teflon from std hose, you'll be buying all new hose ends.
The AN to pipe adapters should be the same 37* flare.
[Re: SealockRacing]
#224149
02/15/09 10:41 AM
02/15/09 10:41 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you want to look for a good hose, look for a hose that has a Viton liner, Viton is impervious to most anything that you would run through it. Its just a thin liner and you can use the regular fittings
