Re: 904 trans cases, late vs early & differences
[Re: cudaman1969]
#2241442
01/26/17 02:27 AM
01/26/17 02:27 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Pre 71 904 cases - I think the breakpoint is 35xxxxx - have a smaller 2nd gear servo than the later cases. I usually use a 5.0 2nd gear band lever for the early cases and 4.2 or 3.8 arms on late model cases.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#2241680
01/26/17 03:19 PM
01/26/17 03:19 PM
Guitar Jones
Pre 71 904 cases - I think the breakpoint is 35xxxxx - have a smaller 2nd gear servo than the later cases. I usually use a 5.0 2nd gear band lever for the early cases and 4.2 or 3.8 arms on late model cases. This is about the only real difference in the cases. Yes some truck cases had ribs cast into them but otherwise they are pretty much the same. I have a non ribbed '73 case in my car and have never broken or cracked it. Now the converter hub is a different story...
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2241823
01/26/17 07:37 PM
01/26/17 07:37 PM
Posts: 8,250 fredericksburg,va
cudaman1969
fredericksburg,va
Pre 71 904 cases - I think the breakpoint is 35xxxxx - have a smaller 2nd gear servo than the later cases. I usually use a 5.0 2nd gear band lever for the early cases and 4.2 or 3.8 arms on late model cases. This is about the only real difference in the cases. Yes some truck cases had ribs cast into them but otherwise they are pretty much the same. I have a non ribbed '73 case in my car and have never broken or cracked it. Now the converter hub is a different story... Would the Dynamic race converters have the hub problem? How about that big spring in the front drum, I heard someone makes a better one?
