Need Help on a 318 ID #2240436
01/24/17 03:01 PM
01/24/17 03:01 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
I cant believe I'm asking what I thought was a question I could answer myself fairly easily...but can someone help ID this 318 engine? based on my limited research it looks like a 1987 engine but I have no idea what application. It does NOT have the roller lifters that I though might be there and it does have the "302" heads.
Engine stamping is 7M31809041220 and the casting # looks to be 4387530 318 7. The pad on the right side by the pan rail is blank.
Thanks.
Scott
Re: Need Help on a 318 ID [Re: 70Sbird] #2240534
01/24/17 05:57 PM
01/24/17 05:57 PM
dogdays Offline
dogdays  Offline
1987 model year Mounds Rd built 318.
Probably came in a pickup or van.
IIRC only passenger cars got the roller cam.
R.
Re: Need Help on a 318 ID [Re: 70Sbird] #2240537
01/24/17 06:01 PM
01/24/17 06:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
4bbl pass cars got a flat tappet cam and 360 heads, not 302 castings.
Not sure what trucks/vans got in 87 for heads, no roller cam though.
Don't be the exception.
Re: Need Help on a 318 ID [Re: 70Sbird] #2240971
01/25/17 12:34 PM
01/25/17 12:34 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
Thanks guys, I suspected a truck or van but couldn't match the casting number to anything.
