Power trunk option on 1971 Roadrunner. #2240446
01/24/17 03:21 PM
01/24/17 03:21 PM
Ottawa, Ontario
L.R Helbling Offline OP
Ottawa, Ontario
I'm wondering if anyone would know if the power trunk option was available on 1971 Roadrunners. If so, would anyone know where the actuator switch was located on the dash and what it looked like?
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240497
01/24/17 05:10 PM
01/24/17 05:10 PM
Chicago
PurpleBeeper Offline
Chicago
I'm not sure, but I "thought" power-trunk was a Fury only or Fury/C-body option????
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240522
01/24/17 05:46 PM
01/24/17 05:46 PM
Ottawa, Ontario
Ottawa, Ontario
I remember years ago during my junk yard days in the late 80's. I found a wrecked Satellite. Not sure if it was a Sebring or Sat Brougham or Sebring Plus. But anyway, I pulled the entire power trunk circuit from the car and transplanted it into my Roadrunner. It fit perfectly. The power trunk unit is correct for a Satellite car. But for some reason,I forgot where the mounting location for the switch and bezel were located from the car I took it out of. I've long ago lost the bezel. It was black with white lettering. The only word on it was "trunk" I ended up mounting it to the left hand side of the driver above the control switch for the Air Grabber but below the Rallye gauges.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240533
01/24/17 05:56 PM
01/24/17 05:56 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I've done the same, they power trunk setup is fairly generic. I pulled one out of a 79 Cordoba and put it in my 72 Dart, the button was in the glovebox.
When I added one to my 87 Diplomat it came out of a similar year 5th Ave, button in the glove box. Got one out of another 5th Ave for my 65 Cuda, guess where the button is? Yep, glovebox.
Maybe yours goes in the glove box.
Don't be the exception.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240613
01/24/17 08:15 PM
01/24/17 08:15 PM
BDW Offline
BDW  Offline
The GM trunk release buttons are plentiful, fit nice in the console.
I didn't like the idea of bending over to the glovebox
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240643
01/24/17 09:14 PM
01/24/17 09:14 PM
Ottawa, Ontario
Ottawa, Ontario
The location of my switch right now is in plain view on the lower part of the dash to the left of the driver location. More convenient than either of yours, I'd guess, only because I don't have to open anything to pop the trunk lid.
Still I'd love to know where the factory designated the location for these switches.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240668
01/24/17 09:53 PM
01/24/17 09:53 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
it never came on a 71b
it can be added easily, as the trunk latch is the
same on many different mopar models..
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240687
01/24/17 10:33 PM
01/24/17 10:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
All the donors I used had the switch in the glovebox was my point, guess I wasn't clear.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240721
01/24/17 11:26 PM
01/24/17 11:26 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Its located in the glove box so there is less likely hood of an accidental opening while driving, there's no lock out when in drive,as fare as an option on 71 Bs I think I recall seeing one with it.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240739
01/24/17 11:47 PM
01/24/17 11:47 PM
Ottawa, Ontario
Ottawa, Ontario
Weird. really weird. I've never seen a glove box with a hole cut out of it to accommodate a power trunk switch from the factory. In fact the only hole I've ever seen on an unmolested glove box insert was for the light.
My 2005 Chrysler 300 C has the trunk switch right there by your left knee. It's got a lock out but lock out's were around in 1971 too.If you guys are telling me that the factory location was in the glove box, I'll accept it.
But the switch bezel that I pulled out of that satellite in the 80's was shaped in such a way that you could read the words "trunk" only when you looked down from the drivers seat on the curvature of the dash. Wish I had a pic of the bezel but it's long gone.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240749
01/25/17 12:00 AM
01/25/17 12:00 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
L.R. you probably right I personally never saw a trunk switch on an early B body probably moved to the glove box in the 80s to cover there a$$.
Re: Power trunk option on 1971 Roadrunner. [Re: 71GTX471] #2240766
01/25/17 12:32 AM
01/25/17 12:32 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
from what i have read in the past and have seen first hand,
i believe that in 71 electric power trunk release
was not a available option.
i'm not sure when it changed over but i have seen a 71 polara with a vacuum operated trunk release.
(i'm guessing in 72 was the change)
the electric power latch was used into the 80's
and that latch will interchange with latches all the way back into the 60's.
(i have seen it done in a 69 charger.)
i have also heard of cars that were coded for it
and don't have it and i also have heard of it in 72 cars??
now i could be all wrong,but that is what i thought
it was.
i have also seen that bezel mentioned in a 72 glovebox before.(that is what it was claimed to be)
someone might correct me as i'm not 100% on this laugh2
maybe someone with a 71 dealer option book can set us straight or shed some light on this..
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240772
01/25/17 12:43 AM
01/25/17 12:43 AM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
Not correct for your car, but here is where it would be located in the glove box.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240776
01/25/17 12:50 AM
01/25/17 12:50 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
is that even a b body glove box?
i have never noticed cut outs on the bottom edge like that before..
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240805
01/25/17 01:42 AM
01/25/17 01:42 AM
Lost Title
Lost Title
I think it's for a later year.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2240921
01/25/17 11:02 AM
01/25/17 11:02 AM
Ottawa, Ontario
Ottawa, Ontario
The pic of the glove box insert and of the switch and bezel are 100% correct. I remember the switch exactly as so and chose to install it near the left knee area on the dash just below the Rallye gauges. The switch in Butterscotch71s photo is actually near the top edge which would makes "some" sense but I suspect that you can't read the words from the drivers seat and the angle is too extreme to read from the passenger seat. You would have to know that a switch is already mounted in that location to operate it.
This is the switch that I remember pulling from that Satellite all those years ago. Don't remember opening anything like a door to get at that switch and I know it was a Satellite based car that had it possibly a 69 or 70 if that makes sense.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2243453
01/29/17 05:06 PM
01/29/17 05:06 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
From page 8-165 in the Dodge Chassis Service Manual for 1971, Fig. 22 - Instrument Panel Accessory Wiring - Coronet and Charger.
I believe the earlier black glove box inserts had a relief line in the form of a circle molded into the side reflecting where the switch was to be placed. It is in this location -
Whether Plymouths were similar, I can't say but the Roadrunner did share many of the same parts.
And they were located in the glove box so that they could be locked away preventing valet access to the trunk in the circumstance you were attending an affair with valet parking (since ignition and glove box keys were different).
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2243458
01/29/17 05:19 PM
01/29/17 05:19 PM
Ottawa, Ontario
Ottawa, Ontario
I'm grateful for your submission, Charger440sixpak. I have an early black glove box insert. I should go back and review to see if mine has the relief lines but it really is starting to make sense to me now. Wish I could find that bezel it may be kicking around somewhere. Of all the desirable options to have, power trunk may, in fact, be the most used for me. Rather than fumble with my keys when I'm parked at a car show, I always go for the little white button to pop the trunk. it's just the easier thing to do.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2243612
01/29/17 09:39 PM
01/29/17 09:39 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Anybody got a part# for the switch? That's pretty cool.
Re: Power trunk option on 1971 Roadrunner. [Re: L.R Helbling] #2243633
01/29/17 09:59 PM
01/29/17 09:59 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I had 4 Imperials with it.they were all vacuum and the button was in glove box.Even the 71 I had was vaccuum.Might have changed over that year to electric.They had a resivoir that held some vacuum when the engine was off so they worked.Rocky
Chrysler Firepower
