What las I need #2239879
01/23/17 05:23 PM
01/23/17 05:23 PM
mississippi
bentwheel43 Offline OP
mississippi
I have a 511" with Eddy RPM head. The cam card has .016 in. and .018ex. what should I set them at.
Section 8 Racing We are nuts about racing.
Re: What las I need [Re: bentwheel43] #2239985
01/23/17 08:31 PM
01/23/17 08:31 PM
Cab_Burge Online work
Cab_Burge  Online Work
Try .010 and .012 cold (.006 tighter cold)and then check them with the motor hot to see how much they end up at, adjust accordingly up scope
Re: What las I need [Re: Cab_Burge] #2240047
01/23/17 09:50 PM
01/23/17 09:50 PM
mississippi
mississippi
so it is tighter with the aluminum heads. thanks Cab It is a street roller cam.
Re: What las I need [Re: bentwheel43] #2240077
01/23/17 10:33 PM
01/23/17 10:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Alum heads grow more than a iron head so you
gap them tighter.. myself I use .004 as a
growth factor.. try .004 -.006 cold then check
them when hot.. you only need to check a couple
EDIT
I was running E-85 so the temp didnt get as high
as a normal gas burner... just check your hot lash
wave
Re: What las I need [Re: MR_P_BODY] #2240091
01/23/17 10:50 PM
01/23/17 10:50 PM
mississippi
mississippi
Thanks Mike, so I am looking for .016 &..018 hot right?
Re: What las I need [Re: bentwheel43] #2240100
01/23/17 11:00 PM
01/23/17 11:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats good with those numbers.. I usually run
a bit on the tight size but you have a tight
lash cam already
wave
