Magnum flywheel #2237379
01/19/17 06:26 PM
01/19/17 06:26 PM
NY,Poughkeepsie
87MO DAK Offline OP
87MO DAK  Offline OP
NY,Poughkeepsie
Quick question
I have a 94 5.2 mag motor with flywheel.
will it work with the factory 833 small block truck bellhousing?
or do i need to get a diff flywheel ?
also what would you recommend for a clutch?
Thanks all
Re: Magnum flywheel [Re: 87MO DAK] #2237585
01/19/17 11:41 PM
01/19/17 11:41 PM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
The magnum should be the 11 inch, 143 tooth flywheel. If you have the aluminum bellhousing, I think you have the 10 1/2 130 tooth flywheel.
Re: Magnum flywheel [Re: 87MO DAK] #2239981
01/23/17 08:29 PM
01/23/17 08:29 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Yes. Magnum uses a 143 tooth wheel.
Several options here...are you keeping EFI?
A large bell for the larger wheel will bolt up, but you will have to notch the bell for the crank sensor.
If you have a small bell, a 130 tooth wheel will bolt to the crank. If keeping EFI, you will need a custom flywheel. Geoff Gerko at Gerko enterprises (www.gerkoenterprises.com) can set you up. Also, you'll have to notch the smaller bell too, or Geoff can set you up with a QuickTime shield that is already notched.
**Photobucket sucks**
