70 cuda road lamp switch #2239728
01/23/17 12:50 PM
01/23/17 12:50 PM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
How do you test a cuda road lamp switch?
Re: 70 cuda road lamp switch [Re: FC7 cuda] #2239896
01/23/17 05:40 PM
01/23/17 05:40 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Well it is an on off switch with 2 terminals. Basically an expensive SPST switch. Single pole single throw. You can use an ohm meter, but there is no load.
The switch turns on a relay. Wire up a device with a small load. Make sure switch does not get hot, indicating corrosion or dirty contacts and higher resistance. The switch does not need to be grounded. Hot from power source on one side, the other side to the relay/ load.
Re: 70 cuda road lamp switch [Re: NANKET] #2239956
01/23/17 07:39 PM
01/23/17 07:39 PM
What Nanket said, start with ohming it cold & see if it does basic on/off. More info on what is going on & what is pointing you toward that switch
Re: 70 cuda road lamp switch [Re: RapidRobert] #2239976
01/23/17 08:23 PM
01/23/17 08:23 PM
New Jersey
FC7 cuda Offline OP
FC7 cuda  Offline OP
New Jersey
I am doing a restoration just wanted to see if the switch is good before I install it
Re: 70 cuda road lamp switch [Re: FC7 cuda] #2240171
01/24/17 12:25 AM
01/24/17 12:25 AM
Alright, makes good sense.
Re: 70 cuda road lamp switch [Re: RapidRobert] #2240285
01/24/17 05:32 AM
01/24/17 05:32 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
I would suggest taking the switch apart and clean the old grease out and re-grease, very simple process that can be done in 5 minutes.
Re: 70 cuda road lamp switch [Re: FC7 cuda] #2240290
01/24/17 09:36 AM
01/24/17 09:36 AM
BDW Offline
BDW  Offline
No need for load, use DMV set to Ohms,
Should be open or short across the terminals as you switch it on/off
Re: 70 cuda road lamp switch [Re: HEMICUDA] #2240835
01/25/17 02:50 AM
01/25/17 02:50 AM
Agreed, if it will come apart I would sparingly regrease the sliding parts & clean the contacts.
