Neutral safety switch wiring
#2239033
01/22/17 03:13 PM
01/22/17 03:13 PM
Posts: 76 georgia
intenseneon
georgia
I have a 2 prong micro switch on the shifter and I still have the factory starter relay.with the relay needed to be grounded. What's the best way to wire in NSs so that it works?.Thanks for the help
69 Dart
Re: Neutral safety switch wiring
[Re: intenseneon]
#2239060
01/22/17 03:42 PM
01/22/17 03:42 PM
Posts: 415 Indiana
Pentastar440
Indiana
Use the switch on the shifter for a line loc etc. All you need is to run the brown wire on the starter relay to the center pin on the transmission .
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
[Re: intenseneon]
#2239113
01/22/17 04:41 PM
01/22/17 04:41 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If you don't want to use the OE switch in the trans, run the ground for the starter relay through the micro switch to ground. Using the OE switch to ground the relay? The micro switch can be removed and thrown in a drawer. Which way you do it depends on where you want the wire run. Don't want to run a wire to the shifter and keep that area free from clutter? Use the trans switch.
[Re: intenseneon]
#2239306
01/22/17 07:36 PM
01/22/17 07:36 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I have a 2 prong micro switch on the shifter Are you sure it's for neutral safety? Some shifters have a switch for the backup lights.
[Re: John_Kunkel]
#2239308
01/22/17 07:40 PM
01/22/17 07:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have a 2 prong micro switch on the shifter Are you sure it's for neutral safety? Some shifters have a switch for the backup lights. My B&M shifter comes with 2 prong mirco switches.. 1 for NSS and a second for reverse lights.. which I dont use
[Re: intenseneon]
#2239389
01/22/17 09:55 PM
01/22/17 09:55 PM
Posts: 76 georgia
intenseneon
georgia
I forgot to metion guys I'm running a powerglide.
69 Dart
[Re: intenseneon]
#2239643
01/23/17 03:03 AM
01/23/17 03:03 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
In that case, run the relay ground from the spade through the micro switch to a ground. "Start" wire direct to the relay "ign" spade.
[Re: CMcAllister]
#2240060
01/23/17 10:08 PM
01/23/17 10:08 PM
Posts: 76 georgia
intenseneon
georgia
In that case, run the relay ground from the spade through the micro switch to a ground. "Start" wire direct to the relay "ign" spade. Thank you!
69 Dart
