Holley 750 DP Passenger Side Fuel Leak #2238439
01/21/17 02:58 PM
01/21/17 02:58 PM
Tennessee
Bunk Offline OP
Bunk  Offline OP
Tennessee
I have recently discovered a fuel leak on my Holley 750 DP carb. It seems as though it is leaking after I shut the engine down. Fuel will puddle on the intake and the fuel line is dry. What could be the cause and fix for this? I'm new to Holley carbs.
The beginning of knowledge is the fear of GOD.
Re: Holley 750 DP Passenger Side Fuel Leak [Re: Bunk] #2238445
01/21/17 03:05 PM
01/21/17 03:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Bowl, metering block gaskets or secondary pump diaphragm.
Re: Holley 750 DP Passenger Side Fuel Leak [Re: Bunk] #2238446
01/21/17 03:06 PM
01/21/17 03:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Float level too high? Power valve/gasket leaking?
Re: Holley 750 DP Passenger Side Fuel Leak [Re: Bunk] #2238447
01/21/17 03:07 PM
01/21/17 03:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Could be loose fasteners, warped mating surfaces, dried-out secondary diaphragm (if double pumper), cross-threaded fitting adapter...
I'd look around the carb & pull it off, check all the mating surfaces for warpage, replace diaphragm (green stands up to alcohol better) & gaskets, check float level, test.
Re: Holley 750 DP Passenger Side Fuel Leak [Re: CMcAllister] #2238678
01/21/17 10:10 PM
01/21/17 10:10 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By CMcAllister
.... or secondary pump diaphragm.
This is my guess. It usually leaks between the rubber part of the diaphragm, and the little metal thing that the pump actuating arm rides on.
Re: Holley 750 DP Passenger Side Fuel Leak [Re: BSB67] #2238907
01/22/17 10:58 AM
01/22/17 10:58 AM
Locomotion Online content
Locomotion  Online Content
I got one of the Holley Super Street all aluminum carbs. I haven't took the time to specifically figure out why it was leaking, but 2 metering block-to-main body gaskets stopped it.
I'll bet yours is "seeping" while the engine is running too. Best to check.
Re: Holley 750 DP Passenger Side Fuel Leak [Re: Bunk] #2238943
01/22/17 12:47 PM
01/22/17 12:47 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have had accelerator pump diaphragms weep on me brand new.
Re: Holley 750 DP Passenger Side Fuel Leak [Re: BSB67] #2238975
01/22/17 01:36 PM
01/22/17 01:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My bad, I read it as leaking IN the manifold. Any of those gaskets could be the problem and sometimes it's just a matter of snugging up the bowl and acc. pump covers.......
