Holley 750 DP Passenger Side Fuel Leak
#2238439
01/21/17 02:58 PM
01/21/17 02:58 PM
Posts: 29 Tennessee
Bunk
Tennessee
I have recently discovered a fuel leak on my Holley 750 DP carb. It seems as though it is leaking after I shut the engine down. Fuel will puddle on the intake and the fuel line is dry. What could be the cause and fix for this? I'm new to Holley carbs.
The beginning of knowledge is the fear of GOD.
Re: Holley 750 DP Passenger Side Fuel Leak
[Re: Bunk]
#2238445
01/21/17 03:05 PM
01/21/17 03:05 PM
Posts: 11,631 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Bowl, metering block gaskets or secondary pump diaphragm.
[Re: Bunk]
#2238446
01/21/17 03:06 PM
01/21/17 03:06 PM
Thumperdart
State of confusion
Float level too high? Power valve/gasket leaking?
[Re: CMcAllister]
#2238678
01/21/17 10:10 PM
01/21/17 10:10 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
.... or secondary pump diaphragm. This is my guess. It usually leaks between the rubber part of the diaphragm, and the little metal thing that the pump actuating arm rides on.
[Re: BSB67]
#2238907
01/22/17 10:58 AM
01/22/17 10:58 AM
Posts: 5,894 Florida
Locomotion
I got one of the Holley Super Street all aluminum carbs. I haven't took the time to specifically figure out why it was leaking, but 2 metering block-to-main body gaskets stopped it.
I'll bet yours is "seeping" while the engine is running too. Best to check.
[Re: BSB67]
#2238975
01/22/17 01:36 PM
01/22/17 01:36 PM
Thumperdart
State of confusion
.... or secondary pump diaphragm. This is my guess. It usually leaks between the rubber part of the diaphragm, and the little metal thing that the pump actuating arm rides on. My bad, I read it as leaking IN the manifold. Any of those gaskets could be the problem and sometimes it's just a matter of snugging up the bowl and acc. pump covers.......
