Under dash connectors and pins??? #2237988
01/20/17 05:16 PM
01/20/17 05:16 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Can the White connector and pins that is part of the dash harness be purchased anywhere???
The blinker switch has one side and the dash harness has the other side. This is for a 72 Road Runner but believe the connector and pins are used in other applications.
Thanks Ron
Re: Under dash connectors and pins??? [Re: RJS] #2238136
01/20/17 10:04 PM
01/20/17 10:04 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
What no help out there today????
Re: Under dash connectors and pins??? [Re: RJS] #2238202
01/21/17 12:16 AM
01/21/17 12:16 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Only place I've obtained it is purchasing a dash wiring harness from year 1. Wonder where M&H gets them.
You can tighten the female molex using a very small screw driver pushed in between plastic connector and female molex in each hole,,,,if that helps you.
Re: Under dash connectors and pins??? [Re: RJS] #2238213
01/21/17 12:36 AM
01/21/17 12:36 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
you are talking about the 8 pin connector that goes to the column.
i do have a few 71-2 parts dash harness's kicking around somewhere
but then i wonder how you would be
able to salvage out the pins??
i also wonder this because
one of my other harness's happens to have that connector broken.
i do have a good spare harness to replace it if i can't fix it correctly.
i have also seen other harness's with the pins have been burnt
on that connection.
Re: Under dash connectors and pins??? [Re: RJS] #2238259
01/21/17 02:36 AM
01/21/17 02:36 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
you have me interested now..
this just might work out
if you can reuse the plastic plug
maybe these kind of pins might work?
they say they are for chrysler..
now on my list to do is to
try to get the pins out from the connector
without boogering it up..
http://www.oreillyauto.com/site/c/detail...8&ppt=C0189
Re: Under dash connectors and pins??? [Re: RJS] #2238261
01/21/17 02:39 AM
01/21/17 02:39 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
http://terminalsupplyco.com/default.aspx
Might check there, I have got a good variety of terminals from them in the past..
Re: Under dash connectors and pins??? [Re: RJS] #2238266
01/21/17 02:49 AM
01/21/17 02:49 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
thanks for the link oz.
i'm going to have to get one apart
and see exactly whats in there.
Re: Under dash connectors and pins??? [Re: RJS] #2238272
01/21/17 03:17 AM
01/21/17 03:17 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: Under dash connectors and pins??? [Re: RJS] #2238295
01/21/17 06:22 AM
01/21/17 06:22 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I order up some females and males from a site found on Google . Males and females come in a variety of sizes. I will check my garage tomorrow to find the size designation required for mopar ignition. There are 2.sizes, one a bit larger than other as I recall.
https://www.amazon.com/s/ref=nb_sb_ss_c_2_14?url=search-alias%3Delectronics&field-keywords=molex+connector&sprefix=Molex+connecto%2Caps%2C248&crid=3GCB6KQCDKSEG
Special tools are recommended to remove from plastic connector and to crimp new pins on wires.
https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Delectronics&field-keywords=molex+connector+removal+tool&rh=n%3A172282%2Ck%3Amolex+connector+removal+tool
Re: Under dash connectors and pins??? [Re: RJS] #2238347
01/21/17 12:17 PM
01/21/17 12:17 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
If you have no problem with the wiring & pin connectors & only the white plastic connector body is damaged it should be relatively simple to swap over a good used one.
Re: Under dash connectors and pins??? [Re: 71GTX471] #2238378
01/21/17 01:23 PM
01/21/17 01:23 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
WoW looks like some great suggestions so far. I have my friend chime in will the burnt part.
Ron
Re: Under dash connectors and pins??? [Re: RJS] #2238467
01/21/17 03:44 PM
01/21/17 03:44 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
If you are not concerned with originality, do what I did and replace those bullet type connectors with a male/female spade and solder, especially in the heavier gauge wires.
On the smaller gauges you can find generic connectors for what's left.
You can stagger the lengths to make a neater bunch, much better solution to the OEM set-up, IMHO.
Joe
Re: Under dash connectors and pins??? [Re: RJS] #2238595
01/21/17 07:43 PM
01/21/17 07:43 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
There is also a special tool that you can purchase at the better auto parts stores that allow you to disengage the locks on these terminals in order to slide them right out of the block connector.
Re: Under dash connectors and pins??? [Re: RJS] #2238783
01/22/17 12:51 AM
01/22/17 12:51 AM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
If you don't have to have OEM, I've had real good luck with Molex brand connectors from Mouser Electronics. Nice quality stuff. They even have high amp connectors for things like electric fan setups.
Re: Under dash connectors and pins??? [Re: RJS] #2238924
01/22/17 12:17 PM
01/22/17 12:17 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I didn't realize the connector was burnt,still mite be able to save the wiring & some connectors would need a thorough examination.
Re: Under dash connectors and pins??? [Re: RJS] #2242228
01/27/17 01:09 PM
01/27/17 01:09 PM
Georgia
1969383S Offline
1969383S  Offline
Georgia
You can buy the housings and connectors directly from M&H.
Gerald
