Grounding my car. Lets start over. #2238050
01/20/17 06:53 PM
01/20/17 06:53 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
So I caused some issues on my car by hastily installing the MS3 box. Lesson learned, don't rush.
Please share your ideas and set ups for how you've got your EFI car grounded. I need ideas.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Grounding my car. Lets start over. [Re: AlexP] #2238125
01/20/17 09:46 PM
01/20/17 09:46 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Alex if you want some pics, i'll probably just go ahead and text you some pics lol!
Im gonna start with the engine grounds, in this pic you can see I have a cable from each head going to a common bellhousing bolt which then has a 1awg cable hanging off that then goes to a through firewall isolated junction stud. Also you can see another cable hanging by the starter, it is the charge wire for the alternator that went through a grommet in the firewall and connected to a 160A marine grade resetable circuit breaker. Those cables were all hand made out of 4 awg shielded cable I got from an implement pivot/generator ag business.
Mopar to the bone!!!
Re: Grounding my car. Lets start over. [Re: AlexP] #2238137
01/20/17 10:07 PM
01/20/17 10:07 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
ok.. your engine block needs to be grounded directly to your battery, both heads should be grounded to each other and then connected to the ground on the block.. ALL modern electronics should be grounded to a wire that is touching the battery. direct grounded
Re: Grounding my car. Lets start over. [Re: mcat4321] #2238143
01/20/17 10:16 PM
01/20/17 10:16 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Your right, but I was'nt finished. The pic below shows the through firewall junction on the dash side.
From there another 1 AWG cable goes up to my buss bar that is isolated from body. You can also see the alternator charge wire connection at the breaker to.
Re: Grounding my car. Lets start over. [Re: AlexP] #2238145
01/20/17 10:22 PM
01/20/17 10:22 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Here is the best pic of the buss bar itself, you cant see it but there is another identical 1 awg cable connection in the lower right corner of the buss bar and THAT cable goes directly to the battery in the trunk.
As far as the Gold box is concerned, you run both + and - wires for it directly to the battery posts.
Re: Grounding my car. Lets start over. [Re: AlexP] #2238194
01/21/17 12:05 AM
01/21/17 12:05 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Not a Gen 3 car but I have an MS3X on my car.
I originally wired it like the manual says, with the grounds going to the back of the cylinder heads. It worked fine or so I thought, I had issues with Datalogs not working properly and reseting all the time. I also had an occasional backfire on startup as well.
After speaking with a well known MS guy he told me the manual is wrong and to remove the grounds to the engine. I did that and ran them off of a dedicated 12 gauge wire that goes to the battery. The only thing on that ground is the MS3 and my Wideband unit(LC2). This took care of the data log problem and the backfire issue.
68 Barracuda Formula S 340
Re: Grounding my car. Lets start over. [Re: Bad340fish] #2238227
01/21/17 12:52 AM
01/21/17 12:52 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I initally had my MS3 grounded to my grounding block but then moved it to the heads just because the instructions said so.
I may try to move the grounds back to the grounding block so its a more direct path to the negative post, maybe lose some weight in the process
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Grounding my car. Lets start over. [Re: AlexP] #2238262
01/21/17 02:44 AM
01/21/17 02:44 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Highly suggest running MS3 + and - 12 awg wires direct to battery posts. Doing this decreases the current load on ALL the component inside that box, ie eliminates heat as much as possible. Im not gonna say my setup is the end all be all, its the first time ive went full retard on a ground strategy like this on one of my builds. One thing I might add to mine is another cable from the starter housing to the firewall stud. Having my battery in the trunk since this car was first ever fired in like 1997, when i did the Gen III swap I changed out all the old cables with 1 AWG hi strand solid copper GOOD cables, ran the 4 awg charge wire from the alt. and it terminates under the dash at my pos 12V junction bar and my pos cable goes from there to battery. Another pos cable goes from there to another through firewall isolated junction stud on the starter side of the firewall. Another 1 awg cable goes from there to starter stud. I have always had a pretty big discrepency between voltage reading at alternator output and at the battery post in the trunk. At one time it was so bad it 14v at the alternator and 13.1 at the battery post, and back then I even had a 8 awg wire that ran direct from alt to battery post. My current setup shows 14.5v at alt and 14.1v at battery post at idle. I did something right here.
Re: Grounding my car. Lets start over. [Re: AlexP] #2238311
01/21/17 10:23 AM
01/21/17 10:23 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I an important thing to remember is that devices feeding info to your ms need to share the same power and ground as the ms unit. A wide band controller is an example of that.
Re: Grounding my car. Lets start over. [Re: 72Swinger] #2238385
01/21/17 01:35 PM
01/21/17 01:35 PM
Candler,NC / Myrtle Beach, SC
JDMopar Online content
JDMopar  Online Content
I gotta ask a dumb question so I can learn something. What is the reason you would use an insulated stud on the ground cable where it goes thru the firewall to the bus bar? Would you not want the body to have multiple ground points, such as a cable from the battery to a rear frame rail, along with the one you wisely provided all the way to the bus bar? Is this well thought out grounding system something that would benefit a factory ECU running the GenIII Hemi in my Duster? I haven't gotten to the wiring phase yet, and trying to learn all I can beforehand. up
Re: Grounding my car. Lets start over. [Re: AlexP] #2238429
01/21/17 02:47 PM
01/21/17 02:47 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Monty did a good write up i the race section with lots of people chiming in.
I'll see if i can find the post.
Re: Grounding my car. Lets start over. [Re: JDMopar] #2238559
01/21/17 06:31 PM
01/21/17 06:31 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Do a google search on 'ground loops'. Sometimes more is not always better.
Re: Grounding my car. Lets start over. [Re: AlexP] #2238612
01/21/17 08:28 PM
01/21/17 08:28 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Anything grounded to the body will then have the body as a giant amplifier of NOISE to contend with as a result. Only thing NOT grounded to my buss bar on my car are my marker lights and tail lights. Only reason a cars body was/is ever used as a grounding point was simply out of convenience, not because of better function. And in the good ole days pre EFI and DIS and ECU's, RF noise from body grounds would on their worst day maybe make a radio station static'y.
Re: Grounding my car. Lets start over. [Re: AlexP] #2238646
01/21/17 09:08 PM
01/21/17 09:08 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
This is BMW's strategy [E70 X5] for localized grounding points. There is just one ground cable from the battery to the chassis on those vehicles, and they are about as loaded up with electronics as they can get. From one I understand, the same strategy still applies today.
Chassis grounding seems to work fine along with a few twisted wires to critical components [ABS/SRS] and shielded wiring for finicky sensors [wheel speed, Crank, Cam, etc.] to cut down on noise interference.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Grounding my car. Lets start over. [Re: AlexP] #2238688
01/21/17 10:29 PM
01/21/17 10:29 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think OE wiring/ECU/sensors etc. have WAY more shielding/isolation built into the components themselves than the aftermarket stuff. I went the route I did because I trust Montes experience with the exact same style of cars/components that I am using. That and a 45 yr old body that still is probably 95% original as the day it was stamped together except for the 45 yrs of rust that I know damn good and well is there in those places you cant see. Another thing that made my decision was this simple thought, how many times have you heard or even wondered yourself when you or someone else has an electrical issue or phantom gremlin with their car and said " I bet its a bad ground" or "something isnt grounding right"? Im happy to say I can look at every single ground connection on my entire car in about 53 seconds.
Re: Grounding my car. Lets start over. [Re: 72Swinger] #2238790
01/22/17 01:00 AM
01/22/17 01:00 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Found his thread.
Very good read!
Unlawful section "Car wiring"
Re: Grounding my car. Lets start over. [Re: MattW] #2238903
01/22/17 10:23 AM
01/22/17 10:23 AM
IN
ahy Offline
ahy  Offline
IN
What has worked well for me (also posted in the race section thread).
ECU and ignition box grounded to battery via heavy cable (#2). I run battery in trunk with a frame ground in the trunk plus a heavy ground cable to the left front frame rail. At that point I installed a stud just above the frame rail that catches the heavy flange of the rail. From that stud another heavy cable to engine block at the factory ground location. I clean the block at the ground location with a flat file and keep it greased and tight for good connection.
The ECU and ignition box are grounded to the stud in the engine compartment and have direct path to the battery via heavy cable. The unibody gets a solid ground front and rear that takes care of everything else.
No ground issues.
Re: Grounding my car. Lets start over. [Re: 72Swinger] #2239179
01/22/17 05:33 PM
01/22/17 05:33 PM
Makes sense, and thanks for the replies. I'm an old guy who thought Mopar Performance electronic ignition kits were a big upgrade......so this new stuff is fascinating to me! laugh2
