Re: MP HEAD ID
[Re: A/MP]
#2237908
01/20/17 03:14 PM
01/20/17 03:14 PM
Posts: 52,972 Romeo MI
MR_P_BODY
They are probably set up for the longer valves like the long valve W-2.. if so then the pedestal is taller and moved over... check a long valve in them before you do any cutting on the pedestals I dont have my books with me to tell you the valve length on the long valve but its in the MP books.. the 3/8 hold down bolts were stock in the performance heads ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: MP HEAD ID
[Re: A/MP]
#2238094
01/20/17 08:48 PM
01/20/17 08:48 PM
fast68plymouth
So. Burlington, Vt.
"EGR hole under the intake" ??
I'm not following you there.
Re: MP HEAD ID
[Re: A/MP]
#2238104
01/20/17 08:58 PM
01/20/17 08:58 PM
Posts: 5,898 Florida
Locomotion
Under the exhaust ports. ![frowwn frowwn](/ubbthreads/images/graemlins/custom/frowwn.gif) Fingers were typing faster than the brain was working! Was thinking about the "intake" pushrod holes.
Re: MP HEAD ID
[Re: Locomotion]
#2238126
01/20/17 09:46 PM
01/20/17 09:46 PM
MR_P_BODY
I knew it couldn't be hard to figure out even though I was getting it wrong! lol All I ever did was plug them regardless of what they were for. Yeah those air injection holes were for emissions.. they pumped fresh air into them so it would pass emissions ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: MP HEAD ID
[Re: A/MP]
#2238360
01/21/17 12:40 PM
01/21/17 12:40 PM
MR_P_BODY
There is a guy on here that does rocker arm work.. sets up the rockers for proper geometry.. his handle is something like G3.. others on here have used him.. maybe they will chime in ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: MP HEAD ID
[Re: MR_P_BODY]
#2238515
01/21/17 04:56 PM
01/21/17 04:56 PM
Posts: 126 Oregon
Jamie McGrath
There is a guy on here that does rocker arm work.. sets up the rockers for proper geometry.. his handle is something like G3.. others on here have used him.. maybe they will chime in Mr.P Body, your thinking of B3RE.
Re: MP HEAD ID
[Re: A/MP]
#2239046
01/22/17 03:27 PM
01/22/17 03:27 PM
MR_P_BODY
Whats the P/N on them... some one should be able to tell you if its a long valve head.. I dont have my books with me so I cant help you there... I have 2 sets of econo W-2s at home.. one set of each.. long valve and standard and they have different stand heights... but with the econo heads they have the cradle cut in the stands for the shafts.. racing version is flat.. they did build a few versions of the race heads that had different stand heights.. one version the stands are basically dont there.. just flat and it uses a tall alum stand.. then some use a short stand ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: MP HEAD ID
[Re: A/MP]
#2239203
01/22/17 05:52 PM
01/22/17 05:52 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Not to add to the confusion but I have a set of '576' heads. Mine are 1.88 valve and the rocker stands are stock configuration with 5/16" rocker shaft hold down bolts. They are basically a 308 without the smog holes. I also have two sets of factory 308 heads from hydraulic roller motors, the pushrod holes are exactly the same as these.
Mopar was offering ported versions of these back then. They were calling them high swirl. I looked in my small bock engine book which was from the late 90s. I believe they used the 576 casting but sold them as a package under a different part number with various levels of porting, stiffer valve springs, etc.
Also looked in my 1998 MP catalog and that's even more confusing with all the different part numbers, nothing resembles exactly what you have.
Plus, I definitely don't see anything that mentions modified rocker stands.
'71 Duster '72 Challenger '17 Ram 1500
