Re: Vintage bias ply front tires, 6.70-15 or 7.10-15??
[Re: HemiStan]
#2237886
01/20/17 01:24 PM
01/20/17 01:24 PM
Posts: 5,202 CT
GTX MATT
CT
I have 6.70-15s on a 4.5 inch Cragar on my car and this is what it looks like...
[Re: GTX MATT]
#2237887
01/20/17 01:25 PM
01/20/17 01:25 PM
Posts: 5,202 CT
GTX MATT
CT
[Re: HemiStan]
#2237934
01/20/17 02:53 PM
01/20/17 02:53 PM
Posts: 44,243 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#2238069
01/20/17 06:35 PM
01/20/17 06:35 PM
Posts: 1,672 Virginia
HemiStan
Virginia
Thanks for the replies and photos! I appreciate it.
My brother put a set of 7.10-15's on his '53 Coronet and they seem wider that the Moroso or Stahl 7.10's. If a set of "new" bias ply 7.10'-15's will fit on a 4 1/2" wheel, that is probably the way I will go.
RMCHGR: How wide is the treat pattern on those Stahls that you have?
Thanks.
Stan
[Re: HemiStan]
#2238076
01/20/17 06:59 PM
01/20/17 06:59 PM
Posts: 1,898 Spahn Ranch
RMCHRGR
Spahn Ranch
RMCHGR: How wide is the treat pattern on those Stahls that you have? About 5" wide.
'71 Duster '72 Challenger '17 Ram 1500
[Re: moparx]
#2238772
01/21/17 11:37 PM
01/21/17 11:37 PM
fullmetaljacket
I used to run these vintage Super Stock Formula 1's before they started drying up too much to be safe at speed. Wish some reputable company or Coker reproduced them and I'd be first in line.
[Re: HemiStan]
#2239268
01/22/17 05:55 PM
01/22/17 05:55 PM
Posts: 10,692 Rittman Ohio
fourgearsavoy
Rittman Ohio
I used the Pro-Trac Competition Front from Coker Tire size 215/70/15 on my Savoy. They worked and looked well for a strip car but you really wouldn't want to do any cornering with them. Very small contact patch and they push into the corner. They have a fat sidewall width and a 3" tread width. I'm on the street more now so I replaced them with M/T S/T radials and The car handles better but doesn't look as cool ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: HemiStan]
#2239511
01/22/17 11:25 PM
01/22/17 11:25 PM
Posts: 12,595 Great Neck,LI,new york
hemi-itis
I ran the Moroso 7.10 on my street/strip car for 20 years.When I updated the rims I went with the MT fronts to match the ET Streets out back. They are good in the street and have been 145 mph in the 1/4.
[Re: HemiStan]
#2239706
01/23/17 10:56 AM
01/23/17 10:56 AM
hemi-itis
Check that the speed rating is good for the speed you will go!
