68-70 B-body rear window seal - where to get?
#223714
02/13/09 08:43 PM
02/13/09 08:43 PM
Posts: 2,158 God's Country - Etowah, TN.
A34
Hey Guys, where's the best place to get a rear window rope seal for 68-70 B-body's? Does anyone know the length required for a 69 Charger and 69 Roadrunner? Thanks !
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: 68-70 B-body rear window seal - where to get?
[Re: A34]
#223717
02/13/09 09:59 PM
02/13/09 09:59 PM
It is a 5/16 butyl tape,available from 3M and other companies too.The 3M package even comes with the rubber blocks for the glass to sit on. Be sure to use butyl tape primer on the pichweld - NOT urethane primer ! Butyl primer can be hard to find nowdays,but it is available and necessary. I like to use the square tape like OEM,but the round will work too,just add some glass sealant around the edges when all done,and make absolutely sure your window trim clips are in place with the correct shallow head screws before you install the glass, or you will be very angry !I prefer to use original clips since the aftermarket ones always seem to be less like spring steel and more bendable than the originals.
#223718
02/14/09 07:49 PM
02/14/09 07:49 PM
A34
Thanks guys !
Anyone know the length required, or does it just come in a standard length roll and you cut to fit?
DEO VINDICE
#223720
03/12/09 04:37 PM
03/12/09 04:37 PM
Why won't the urethane primer work? This is all I have been able to find. I can't find butyl primer anywhere, and the 3M stuff appears to be discontinued.
#223721
03/13/09 12:34 AM
03/13/09 12:34 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I always paint mine before I install the glass... I never even hear of butyl primer.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
