Rim blow #2235911
01/17/17 11:00 AM
01/17/17 11:00 AM
Sharpsburg Maryland
440farmer Offline OP
Sharpsburg Maryland
How hard is it to replace the switch in the wheel?
Are special tools needed? Is it a PITA?
Re: Rim blow [Re: 440farmer] #2235957
01/17/17 12:45 PM
01/17/17 12:45 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If the old one had a melt down then yeah a lot of digging and filing to open up the pocket/groove, plus the dried glue to contend with, not a hard job, but time consuming
Re: Rim blow [Re: 440farmer] #2236027
01/17/17 02:18 PM
01/17/17 02:18 PM
Sharpsburg Maryland
Sharpsburg Maryland
Ok where's a good place to get the switch
and are they aftermarket or Chrysler
Re: Rim blow [Re: 440farmer] #2236074
01/17/17 03:24 PM
01/17/17 03:24 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Some substitute the Ford switch which will require mods to use, www.early-birds.ca has a repro switch for the 70-1 mopar B/E steering wheel, IIRC it's about $60
Re: Rim blow [Re: 440farmer] #2236116
01/17/17 04:29 PM
01/17/17 04:29 PM
Sharpsburg Maryland
Sharpsburg Maryland
Called and talked to them and they said soon?? not available yet??
Thanks anyway
