Steel versus Nylon Braided Fuel lines #223523
02/13/09 05:04 PM
02/13/09 05:04 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Just about to get Fuel lines installed. Any thoughts on the Nylon versus braided steel lines. The only advantage that I can see with nylon is that it is easier to install. I would expect them to be less durable.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Steel versus Nylon Braided Fuel lines [Re: Kam*Kuda] #223524
02/13/09 05:37 PM
02/13/09 05:37 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
personaly i'd go steel. my concerns with nylon is durability when you have a wee fire. you never expect to have fire, but you never know when your competition in the brand X car, in the next lane has an ooopsy & crashes into you & you're both on fire. will those nylon fuel lines not melt thru in the short time you need to get your butt outta the chair & escape? i don't know but do you feel lucky?
Re: Steel versus Nylon Braided Fuel lines [Re: Kam*Kuda] #223525
02/13/09 05:39 PM
02/13/09 05:39 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I think you have to read the rule books. I believe you are allowed no more than 12" of rubber fuel line.
Re: Steel versus Nylon Braided Fuel lines [Re: Kam*Kuda] #223526
02/13/09 06:37 PM
02/13/09 06:37 PM
AndyF Offline
AndyF  Offline
I use the Aeroquip Socketless hose for all my fuel and oil lines. It is easy to install and the fittings are a lot less expensive, especially in steel or brass. It is also easier to keep clean than the lines with the SST braid.
Re: Steel versus Nylon Braided Fuel lines [Re: rebel] #223527
02/13/09 07:33 PM
02/13/09 07:33 PM
Orlando Florida
blown572dart Offline
Orlando Florida
I think that in a fire even stainless braided hose will melt inside and will not make a diffrence. I can tell you that the black braided hose does not hold up to fire form personal expierence.
Re: Steel versus Nylon Braided Fuel lines [Re: blown572dart] #223528
02/13/09 07:39 PM
02/13/09 07:39 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i can tell you from experience that in a fire situation the braided steel line is no better,i think that it may be worse becuase it can get hot enough to blister and still look good on the outside.
Re: Steel versus Nylon Braided Fuel lines [Re: Kam*Kuda] #223529
02/13/09 08:44 PM
02/13/09 08:44 PM
AndyF Offline
AndyF  Offline
I don't think the NASCAR boys use SST hose anymore at all. Every picture I've seen lately the cars are plumbed with the lightweight black braided hose with crimped on fittings.
Re: Steel versus Nylon Braided Fuel lines [Re: AndyF] #223530
02/13/09 08:52 PM
02/13/09 08:52 PM
is any of the nylon braided hose even legal in NHRA? i haven't found any yet that says it is.
i'mnot a fan of the socketless hose either. isn't that just a PVC hose? is it legal for NHRA?
Re: Steel versus Nylon Braided Fuel lines #223531
02/13/09 09:13 PM
02/13/09 09:13 PM
Chicagoland
chargerron69 Offline
Chicagoland
i had some black nylon hose for tranny lines and got too close to the header and melted a hole in it. i still like the steel line all though the nylon is much lighter
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: Steel versus Nylon Braided Fuel lines #223532
02/13/09 09:47 PM
02/13/09 09:47 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
NHRA told me the blue Aeroquipt socketless hose was legal for all fluids.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Steel versus Nylon Braided Fuel lines #223533
02/13/09 11:05 PM
02/13/09 11:05 PM
AndyF Offline
AndyF  Offline
Sounds like you need to keep up with the times. NHRA has allowed various types of hoses for a long time. Part numbers are listed in the rule book.
Re: Steel versus Nylon Braided Fuel lines [Re: AndyF] #223534
02/14/09 12:10 AM
02/14/09 12:10 AM
not sure who your referring to but i was told by russell that their nylon braided hose was not NHRA approved. i got a similar response from Earls.
i know some of the steel braided line IS approved though.
the nylon braided hose is very popular because of its lightweight and ease of assemble.
