A-body 408 gears?? #2235068
01/16/17 01:11 AM
01/16/17 01:11 AM
Hershey,PA
mracer360 Offline OP
Hershey,PA
Currently running my 69 dart 340/727 with 4.56 gears 275/60 drag radials. Car runs 12.0-12.20 1/4 mile. Maybe putting in my 408 went 10.80 in same weight car with glide. What gears do I need to slow this thing down to 11.50-11.80 with same trans tire combo.
Re: A-body 408 gears?? [Re: mracer360] #2235101
01/16/17 01:56 AM
01/16/17 01:56 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
2.94
Re: A-body 408 gears?? [Re: mracer360] #2235146
01/16/17 03:10 AM
01/16/17 03:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What I did to slow my car down to run 10.0
stuff was put a mech throttle stop on it and
lower the launch and shift rpm... you can also
slide your throttle cable in so you only open
the throttle part way... if you change gears in
it you will be WAY under your torque point and
be forever in low gear... I used the trottle stop
on mine so I could run 2 classes and change over
quickly.. this is what I built to fit on the carb
wave
Re: A-body 408 gears?? [Re: MR_P_BODY] #2235446
01/16/17 05:27 PM
01/16/17 05:27 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I run a 408 also because it makes 52 more lbs. of torque than my previous 363 i was going thru the traps at over 7.000 I went to a 4.10 but I am only going thru at 5,700 I am changing to 4.30s pretty soon. My Dart runs 10.70s but I slow it down to run 11.50s with a setup pretty similar to Mr Ps. , I might add that my 60 fts. remained the same going from 4.88s to the 4.10s because of the torque. Heres a picture of my stop, I have been running it for 8 years now and it works well.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: A-body 408 gears?? [Re: 11secdart] #2235484
01/16/17 06:12 PM
01/16/17 06:12 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
About 4 yrs. ago I broke the 5.14's I was running in my D50. The best pass at that time was a 6.34 @ 108 in the 1/8. I stuck a chunk with 3.50 gears in so I could go race and it ran a best of 6.39 @ 109 crossing the finish line in 2nd gear. It lost the half a tenth in the 60 ft. I am now running 4.56 gears. It needs something lower than the original 5.14's.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
