fast ezefi #2235011
01/15/17 11:52 PM
01/15/17 11:52 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
bit the bullet and bought a kit for my 69 rr
any one have any refernce pics / tips for istall ??
I dont want to drill a hole in firewall, looks like i might need to . ?
Thank in advance
Re: fast ezefi [Re: sogtx] #2235345
01/16/17 03:21 PM
01/16/17 03:21 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Should this be in the racing forUm ?
Re: fast ezefi [Re: sogtx] #2235475
01/16/17 05:54 PM
01/16/17 05:54 PM
East Tennessee
Burkenator Offline
Burkenator  Offline
East Tennessee
I installed the EZEFI (original version) on my car about 3 years ago. Plan out where you want everything to go before you actually start installing it (e.g.--location of ECU, wire routing, etc.) I didn't do to well at this and ended up having an extra hole in my firewall. It was also recommended to me to run a dedicated switched power line from the ECU to the battery. Do not hook the wire into switched power in the fuse box. It will have too much electrical interference and will not run right. I ran my switched power line with a toggle switch. Not sure what kind of fuel line they are supplying with the kit now. The original line they sent was a mother to get on the supplied fittings. I went and ordered different fuel line/fittings from Summit. Much easier to assemble. I went with an in-tank fuel pump instead of the external pump. Much quieter, but more expensive. It has worked out well for me. I think you will like it.
Re: fast ezefi [Re: Burkenator] #2235522
01/16/17 07:32 PM
01/16/17 07:32 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Use a relay wired directly from the battery thru the relay to the pink wire going to the EFI. Control the relay with switched ignition power. The EFI will keep going into fault mode if the pink wire has any interruption in steady power or low voltage.
Re: fast ezefi [Re: Dabee] #2237031
01/18/17 11:57 PM
01/18/17 11:57 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Thanks for tips so far ..
