14" X 5 1/2" Factory Rallye Wheel Backspacing #2234343
01/14/17 11:44 PM
01/14/17 11:44 PM
North of the Motor City
DartGTDan Offline OP
Can someone confirm the backspacing of a 14" X 5 1/2" small bolt pattern (5 on 4") factory Rallye Wheel?
I thought I read somewhere that they have 3 1/2" backspacing.
Re: 14" X 5 1/2" Factory Rallye Wheel Backspacing [Re: DartGTDan] #2234457
01/15/17 02:49 AM
01/15/17 02:49 AM
I have a couple of ralleys & I will check tomorrow for you but I don't remember if they are BBP or SBP (too many projects!)
Re: 14" X 5 1/2" Factory Rallye Wheel Backspacing [Re: RapidRobert] #2234751
01/15/17 04:37 PM
01/15/17 04:37 PM
My wheel BS is 4" to the circular flat where the 5 holes are and 3&3/4" to the raised circular "bead" areas on either side of the circular flat. this is a 14 x 5&1/2 rim but it is BBP and has 70/71 B/E body on it in permanent junkyard ink
Re: 14" X 5 1/2" Factory Rallye Wheel Backspacing [Re: DartGTDan] #2235595
01/16/17 09:16 PM
01/16/17 09:16 PM
Midwestern Indiana
duster2 Offline
Happy Birthday duster2  Offline
Midwestern Indiana
3 5/8 Backspace...
Re: 14" X 5 1/2" Factory Rallye Wheel Backspacing [Re: duster2] #2239016
01/22/17 02:51 PM
01/22/17 02:51 PM
Originally Posted By duster2
3 5/8 Backspace...
Thank you sir!
