Re: Dragweek 2017 Questions
[Re: Dart451]
#2233275
01/13/17 01:42 AM
01/13/17 01:42 AM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
They ask stuff like your name and adress, what car, licence plate #, insurance co and policy #, what class, what ET will it run, and info about the car that the announcers can talk about. Like the story behind it, how long you"ve owned it, the modifications.
When you get to registration, you can change car, change class, but you can not change to a different entrant/driver.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Dart451]
#2233304
01/13/17 02:32 AM
01/13/17 02:32 AM
Hemi_Joel
Minnesota
Sounds like a good, fun plan. Just remember that you need drag tires on the track.
[Re: Dart451]
#2233446
01/13/17 12:36 PM
01/13/17 12:36 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Pictures of Kim in Daisy Dukes would help us visualize the theme
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#2233452
01/13/17 12:50 PM
01/13/17 12:50 PM
Posts: 10,045 MN
JERICOGTX
MN
Pictures of Kim in Daisy Dukes would help us visualize the theme Would it change your mind about not going this year?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2233460
01/13/17 01:06 PM
01/13/17 01:06 PM
sixpackgut
Charleston
Pictures of Kim in Daisy Dukes would help us visualize the theme Would it change your mind about not going this year? Probably not. I can spend 5 days in bobbie bar and spend less money
[Re: sixpackgut]
#2233481
01/13/17 01:48 PM
01/13/17 01:48 PM
Posts: 668 IL
Dart451
IL
Pictures of Kim in Daisy Dukes would help us visualize the theme Not shorts but close enough.
[Re: Dart451]
#2233570
01/13/17 04:36 PM
01/13/17 04:36 PM
Posts: 861 lancaster,california
johnnycuda
Pictures of Kim in Daisy Dukes would help us visualize the theme Not shorts but close enough. Lucky man, good luck at Drag Week!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: Dart451]
#2233592
01/13/17 05:12 PM
01/13/17 05:12 PM
Posts: 200 AB
Efidart
AB
If you don't get registered and just show up you will still get in. They have yet to ever turn away anyone that shows up on registration day.
There are many people that register and talk about going but in the end its all hot air. If you are serious about it get right on it, don't make excuses and figure out a way to not go just before hand.... take your car on a few long drives and ensure it can sit in rush hour traffic for long periods of time.
It is one of the most fun things you will ever do in your life, also one of the hardest. Hope to see you there!
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: Dart451]
#2233610
01/13/17 05:32 PM
01/13/17 05:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've entered a couple of times but failed to make it there.. trans has been a issue in the past.. I went through 3 trannys in 2 summers and last year the injection didnt want to play right.. I wont even try to register.. if my junk is running right I will just show up.... I have been on it 3 times with my buddy and we had a great time.. it is a bit^h but fun
[Re: Dart451]
#2233637
01/13/17 06:31 PM
01/13/17 06:31 PM
sixpackgut
Charleston
Pictures of Kim in Daisy Dukes would help us visualize the theme Not shorts but close enough. Nice. That will work
[Re: Scott58]
#2233750
01/13/17 09:56 PM
01/13/17 09:56 PM
MR_P_BODY
Just a note, to my knowledge there is no 11.50 index class at Drag Week, unless they are adding a new one this year. Sadly, you will likely not make the quick 32 for eliminations in Street Machine Eliminator with an 11.50 car. No 11.50 doesnt cut it in SME class... and no there isnt any 11.50 class...just the point where you need a roll bar unless its a new ride but I'm not sure if DW follows that rule.. but I think they do
[Re: Dart451]
#2234108
01/14/17 06:09 PM
01/14/17 06:09 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I'm going to pull my old 72 Scamp out of the snow bank soon and get it on the road this summer. I would really like to make it to Drag Week as it's not that far this year from Winnipeg. When I go to register what would be the class that it would run in? The car is tubbed and the springs are moved in and I have a 340 ready to drop in ....would I go in Modified Small Block N/A or Street Race Small Block N/A....if anyone knows thanks!
A new iron curtain drawn across the 49th parallel
