Re: Pickiing a mild street cam for a Magnum 360
[Re: 300by500]
#2232050
01/11/17 01:25 AM
01/11/17 01:25 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The MP 380hp 360 crate motor was essentially a stock long block with an M1 4bbl intake, MP ignition and a cam swap. And that cam was a whole lot milder than the one you are looking at. http://www.hotrod.com/articles/mopp-0303-360-crate-engine-buildup/
[Re: 300by500]
#2232087
01/11/17 02:46 AM
01/11/17 02:46 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Hughes whiplash cam and matching springs, retainers. No machine work needed on stock heads. 222/228 107 lsa 104 icl. .544/.544 with stock 1.6 rockers.
Bone stock short block, bone stock heads. M1 single plane EFI intake. Mid length headers. The truck put down 285 rwhp. At 4000 lbs it was running mid 14s with 2.2 second 60' times, tripping at 96-97 mph.
I added Edelbrock heads and changed nothing else, dyno'd at 325 rwhp, low 14s with the same traction limited 60' times and at 99 mph now.
Idles at 9" but brake booster is happy unless you're rapidly pumping the pedal. Strong off idle torque, all done by 5500 rpm
A great street cruiser cam.
**Photobucket sucks**
[Re: 300by500]
#2232248
01/11/17 01:15 PM
01/11/17 01:15 PM
70Cuda383
Marysville, O-H-I-O
They must have changed something then. When I bought mine, they called for the 1110 springs
[Re: 70Cuda383]
#2232326
01/11/17 04:10 PM
01/11/17 04:10 PM
Posts: 2,886 Bowling Green KY / Nashville, ...
300by500
They must have changed something then. When I bought mine, they called for the 1110 springs If the specs of the cam haven't changed and you ran the 1110 Springs with no issues maybe I should consider possibly giving it a shot? Hmmm...
[Re: 300by500]
#2232333
01/11/17 04:21 PM
01/11/17 04:21 PM
70Cuda383
Marysville, O-H-I-O
I just looked. They definitely changed the cam. When I bought it, it was a 222/228 107 on a 104 with .544 lift
Now it's a 223/237 107 on a 102. Lift is .549/.576
Call and ask for the 'old whiplash specs'.
[Re: dogdays]
#2232338
01/11/17 04:27 PM
01/11/17 04:27 PM
300by500
Hughes states very clearly in their catalog that the Whiplash cams are not for stock compression Mag engines, that one should go to either 110 or 114 LSA.
The reason they don't recommend them for Magnum engines is because of the increase in cylinder pressure. I don't think I've got too much to worry about, with nearly 200,000 miles on the engine more cylinder pressure would be a good thing.
[Re: 300by500]
#2232350
01/11/17 04:58 PM
01/11/17 04:58 PM
70Cuda383
Marysville, O-H-I-O
The other thing is that most magnum engines are in computer controlled EFI vehicles. It will NOT run very well without extensive tuning via SCT or other stand alone EFI. So they put a disclaimer out there to scare away inexperienced guys from tossing it into an otherwise bone stock truck.
[Re: 300by500]
#2232554
01/11/17 11:28 PM
01/11/17 11:28 PM
Supercuda
About to go away
About to go away
up yours
MP crate cam 288* / 292* roller. .501"/.513" lift (230*/234* @ .050)108 LSA
OP's proposed cam 539/549 lift, 218/222 duration@ .050, 110 LSA
Define radical.
MP's cam will fit a stock magnum head.
You will have to most likely trim the guides to fit the Hughes cam, kinda gets away from the LOW BUCK aspect.
Both will need new springs.
[Re: 300by500]
#2233390
01/13/17 10:06 AM
01/13/17 10:06 AM
70Cuda383
Marysville, O-H-I-O
That's also a good point. Power on paper looks impressive. Power on the street feels impressive. Often times, the lesser hp motor will outpull the one that puts down a larger number on paper.
That's why it's important to remember that with non-variable valve timing, you will have about 4,000 RPM power band. if motor A makes 300 ft lbs of torque from 1500-5500, you will max out at around 300 hp. If motor B makes 300 ft lbs from 3,000 to 7000, you will make about 100 hp more. But motor A will outpull motor B on the street 9 times out of 10. (That 1 time it does, it's because the car is set up for it with steep gears, loose converters, and manual brakes... a combo that most will call 'race car and not street friendly' because you gotta give it 3,000 RPM just to 'idle' through traffic.)
[Re: 300by500]
#2233397
01/13/17 10:50 AM
01/13/17 10:50 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Some years of the Magnum 5.2 cam are a bit more intake duration and produce a peak HP in the 4400 to 4800 rpm range versus 3800 to 4000 for the 1994-1996 Magnum 5.9 camshaft. The Ram 1997 camshaft changed, and the 1998 5.9 Jeep Cherokee camshaft may also vary.
For the street do not give up idle vacuum
[Re: 300by500]
#2233400
01/13/17 10:56 AM
01/13/17 10:56 AM
Posts: 158 Georgetown de usa
Eggman
Georgetown de usa
Comp cams 264-HR-12. 210/220-.480/.480 112 lsa with their 901 springs👍
