Header size
#223121
02/13/09 09:29 AM
02/13/09 09:29 AM
Posts: 317 Indiana
79_W200
Indiana
i have a 470(400) roller cam in the 280's at .050 est. hp around 650 rpm is going to be 7000-7500 it is in a 79 truck and the only headers i can find that fit are 1-3/4 primary i was wanting to run a 2" primary how much will the small tubes hurt hp
1979 W200 470
Re: Header size
[Re: mopar dave]
#223123
02/13/09 10:54 AM
02/13/09 10:54 AM
Posts: 8,165 Left Coast
BobR
Left Coast
there's people out there runnin 10's with 1 3/4 headers. i think 1 7/8 would be ideal, but 2" is over kill unless your sprayin.
I disagreee. I think that you need at least 1 7/8" stepped to 2" for the kind of power you are running. I usually get my headers made as I can seldom find off the shelf headers that I am happy with.
Re: Header size
[Re: 506RR]
#223126
02/13/09 01:36 PM
02/13/09 01:36 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Years ago I dyno tested a 426 M.W. pump gas street motor on a new DTS engine dyno, the shop did not have a set of dyno headers made up yet so we used a set of Hooker A body 1 7/8 primary tubes about 40 inches to the collectors and 3.5 inch colletors for the first 23 pulls while the shop made up a set of dyno headers. The shop made a set of 2 1/4 primary pipes that where around 25 inches long and 4 inch collectors for there dyno headers, we swap the headers with no other changes and the motor pick up HP all the way thru the RPM range, 3500 to 6500 and lost some torque down low, below 4000 rpm, on the averages the bigger headers made more torqure and HP than the smaller tube set made
Re: Header size
[Re: Cab_Burge]
#223127
02/13/09 02:34 PM
02/13/09 02:34 PM
Posts: 317 Indiana
79_W200
Indiana
what price range does a custom made set of headers run
1979 W200 470
