Page 4 of 5 1 2 3 4 5
Re: is the BFG radial T/A the only 15" tire left? [Re: furious70] #2224826
01/01/17 03:51 PM
01/01/17 03:51 PM
jersey
Spaceman Spiff Offline
jersey
Originally Posted By furious70
I might have the room, but don't most people really dislike that much tire up front with stock suspension and steering? Thought I've heard people complain that the car will grab and pull with that much tire up front.
If you have manual steering, your arms aren't going to like a wider tire.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: is the BFG radial T/A the only 15" tire left? [Re: Spaceman Spiff] #2224835
01/01/17 04:03 PM
01/01/17 04:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Hmm, when my 64 300 lost it's power steering pump I drove it without power assist for years.
I was running P245/60R15's in the front, 9.6" wide at teh tread.
Steering a no assist power steering setup is harder than a manual steering setup.
Stock power steering ratio is 15.7:1, but without the larger steering wheel or alignment specs a dedicated manual steering car has.
It was a stick too.
Never had a problem driving it and I was driving it in San Diego at the time.
Guess it's all in the mindset. My Cuda has manual steering, but it the 24:1 setup, yay, not. It'll, eventually, get a 16:1 setup.
Don't be the exception.
Re: is the BFG radial T/A the only 15" tire left? [Re: TC@HP2] #2224838
01/01/17 04:06 PM
01/01/17 04:06 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Originally Posted By TC@HP2
Originally Posted By Centerline
I don't know.... Cooper tires are still made in the USA, although they do own tire companies in the UK and China. I know opinions vary on whether they make any UHP tires, but it just seems wrong to put foreign tires on an American classic. Even Michelin tires make my skin crawl.
My goof. I thought they were owned by the Brits. I guess it is the other way around, which actually is pretty cool. Avon makes the only remaining Z rated UHP 15" tires out there for handling applications.
Looks like Cooper also owns MT, which explains why the MT ST and Cooper Cobra look nearly identical. They also own 11% of Kumho and 51% of Chengshan. For other fans out there, Cooper also makes Dean, Futura, Arizonian, Mastercraft, Starfire, Hercules, and Sears Gaurdsmans.
Far out man!
They also make Mastercraft tires.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: is the BFG radial T/A the only 15" tire left? [Re: mopargem] #2224841
01/01/17 04:08 PM
01/01/17 04:08 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
Originally Posted By mopargem
It's pretty well known now that with some of the BFG radial ta's the white letter turns brown so they need to be boycotted until the problem is solved. One of my tires letters looks awfull brown and couple others are ivory.
Yep, I'm in the same boat. None of the various solutions suggested here on Moparts have corrected the situation. It's definitely in the compound. So, if you do buy BFG, I'd recommend buying local and understanding the warranty. Make sure they will replace them, if they turn brown. That way, you're covered, even though it's a pain to have to get it done.
I ordered mine from Amazon using points and there's really no way to get them warrantied, especially with shipping costs. Keep that in mind on any tire you order online. I'm not saying don't order online, just understand the ramifications if there's an issue.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: is the BFG radial T/A the only 15" tire left? [Re: Dixie] #2224919
01/01/17 05:20 PM
01/01/17 05:20 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Was in a local tire shop here last week...
They've been around for many years...
Talked about the T/A letter-bleeding issue...
Said they've never seen it...
Re: is the BFG radial T/A the only 15" tire left? [Re: RSNOMO] #2225081
01/01/17 09:30 PM
01/01/17 09:30 PM
jersey
jersey
when was the last time they sold one......
i'm sure it's a popular tire for Joe average.....
Re: is the BFG radial T/A the only 15" tire left? [Re: furious70] #2225151
01/01/17 11:18 PM
01/01/17 11:18 PM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
Feets, what brand and size do you recommend to replace a 275/60-15 and 235/70-15?
Re: is the BFG radial T/A the only 15" tire left? [Re: Airgrabber] #2225167
01/01/17 11:36 PM
01/01/17 11:36 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Here's mine on the charger. BF Goodrich should call them Raised Brown Letter tires.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: is the BFG radial T/A the only 15" tire left? [Re: Supercuda] #2225449
01/02/17 12:10 PM
01/02/17 12:10 PM
IL
furious70 Offline OP
IL
It was a stick too.
With a big block, a/c, and a twin turbo setup hanging out up front, I prefer the power steering turning the 235's smile
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: is the BFG radial T/A the only 15" tire left? [Re: Airgrabber] #2225497
01/02/17 01:13 PM
01/02/17 01:13 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The hot rod had tires in those sizes. when it came time to replace them I used Nitto NT555 in 245/45-18 and 295/45-18.
- Stu Harmon
Re: is the BFG radial T/A the only 15" tire left? [Re: furious70] #2225524
01/02/17 01:40 PM
01/02/17 01:40 PM
IL
IL
hey - post a good pic of the hot rod side profile with those rims, been way too long since I've seen it - I want to see the sidewalls
tirerack only shows these when I search for a set of those sizes
http://www.tirerack.com/tires/TireSearch...rearDiameter=18
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: is the BFG radial T/A the only 15" tire left? [Re: furious70] #2227081
01/04/17 02:02 PM
01/04/17 02:02 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Maxxis MA-S1 Update:
I downloaded their tire brochure and it gave information on most of their tires (off road to competition). Since the UTQG rating is based on each tire manufacturer, I wanted to review their ratings to see where the MA-S1 rated. They show the following UTQG ratings:
AC-1 Competition tires as 100
MA-S1 tires as 360 (apx. 30k miles) SUV/LT All Season Performance
MA-P1 tires as 380-440 (40-50k,) Performance Touring
MA-1 tires are 480 (60k miles) Grand Touring
CUV tires are 520 (60k miles) Crossover Premium Touring
MA-T1 tires are 560-720 (60-100k miles). Premium Touring
So it looks like from using Maxxis's own UTQG ratings, the MA-S1 tires may be "stickier" than most of the passenger type tires that they produce.
The MA-S1 tires are a black wall SUV/Light Truck All Season Performance Tire and their P295/50R15, P275/60R15, P255/60R15, and their P245/60R15 are all rated at 44psi for maximum pressure and have the H speed rating (130mph).
I just wanted to throw this out there for reference.
Attached PDF document
Re: is the BFG radial T/A the only 15" tire left? [Re: furious70] #2230295
01/08/17 07:57 PM
01/08/17 07:57 PM
Germany
fc7_plumcrazy Offline
Germany
I am glad to love driving my Goodyear Polyglas GT tires a lot.
Carsten
Re: is the BFG radial T/A the only 15" tire left? [Re: fc7_plumcrazy] #2230523
01/09/17 12:31 AM
01/09/17 12:31 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Carsten
I have them and love the look but care not for the stiff ride. Perhaps with Coker coming out with a Firestone Wide Oval looking radial tire, hopefully we will see same for Goodyear Poly's one day.
Being in Germany and with the autobahn and all, with many areas of no speed limits, brought to mind an old question of mine. Does anyone know if there is a speed rating on these reproduction bias ply RWL Goodyears such as on modern tires.
Re: is the BFG radial T/A the only 15" tire left? [Re: furious70] #2230610
01/09/17 02:46 AM
01/09/17 02:46 AM
ME
79machocharger Offline
ME
I also hope Goodyear comes out with a radial with the original poly glas raised white letter look. The look of a radial tire kills me on these old mopars.
Re: is the BFG radial T/A the only 15" tire left? [Re: furious70] #2231102
01/09/17 09:30 PM
01/09/17 09:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Here are some quickies I found of it on the net.
- Stu Harmon
Re: is the BFG radial T/A the only 15" tire left? [Re: furious70] #2231162
01/09/17 10:45 PM
01/09/17 10:45 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I remember when a shaved TA was a track tire.
Have a great day
Iowan
"obsolete is neat"
Re: is the BFG radial T/A the only 15" tire left? [Re: furious70] #2231350
01/10/17 01:51 AM
01/10/17 01:51 AM
IL
IL
not sure I like the smaller tire on the bigger plymouth, this is a 235/55/18 from my 2012 Charger, 28" just like the 235/70/15
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: is the BFG radial T/A the only 15" tire left? [Re: furious70] #2231506
01/10/17 11:53 AM
01/10/17 11:53 AM
blewbyu Offline
blewbyu  Offline
I just put Cooper cobra's on my 67 drive
Re: is the BFG radial T/A the only 15" tire left? [Re: furious70] #2231573
01/10/17 01:29 PM
01/10/17 01:29 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
A big part of it is the wheel.
If your wheel doesn't compliment the car them it'll always look bad.
Think about the factory setup with whitewalls. The whitewall was closer to the bead than the tread. It gave the impression of a larger diameter wheel.
Get the proper wheel and you can bring back some of that look. It'll be okay.
On your C barge I'd look for a 29" tire.
I run a 29.5" tire on the Imp.
- Stu Harmon
