motor question #223079
02/13/09 07:51 AM
02/13/09 07:51 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
I kinda experince a weird vibration at idle from my 5.2 it a 99 model truck... I replace the wires and cap and rotor which were toast could it be the cap and rotor again? it goes away when I rolling along it just when I seat at a light or stop sign.
Re: motor question [Re: BigTerry] #223080
02/13/09 08:09 AM
02/13/09 08:09 AM
You could have a bad mount.
Re: motor question #223081
02/13/09 02:04 PM
02/13/09 02:04 PM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
if it was a bad mount wouldn't the motor rise when you goose the throttle?
Re: motor question [Re: BigTerry] #223082
02/14/09 01:10 AM
02/14/09 01:10 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
Re: motor question [Re: BigTerry] #223083
02/14/09 12:17 PM
02/14/09 12:17 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You have to determine if it's a miss or vibration. That's what will be hard to do on this here internet. If it's a misfire, it could be anywhere from a cracked plug to a burnt valve or even more serious. If it's a vibration, it could be from a mount problem to balancing problem, exhaust pipe against frame etc.
Re: motor question [Re: buildanother] #223084
02/15/09 02:24 AM
02/15/09 02:24 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
I been think it might be a bad injector?? it not a driveline vibration that wouldn't be noticeable sitting with truck idling or would it??
Re: motor question [Re: BigTerry] #223085
02/17/09 07:45 AM
02/17/09 07:45 AM
Alexandria,La.
BigTerry Offline OP
BigTerry  Offline OP
Alexandria,La.
