Suggestions for Hellcat Supercharger Bypass #2228724
01/06/17 05:17 PM
01/06/17 05:17 PM
USA
hudsonhornet7x Offline OP
USA
The Hellcat supercharger uses a electric throttle body as a bypass when not building boost. A regular supercharger uses a vacuum bypass I believe. I am looking for ideas on what would be needed to either run the electric bypass or retrofit a vacuum unit.
The pic is showing the bypass itself for reference.
Thanks for any help as this is the last hurdle to make our swap work.
dodge-370ci-v-8-supercharged-hellcat-hemi-engine-bypass-valve-repurposed-throttle-body.jpg
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2228728
01/06/17 05:22 PM
01/06/17 05:22 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Could be tricky, Efisource was saying they had one running. Wonder why Mopar doesn't offer a plug and play for these as well.
Mopar to the bone!!!
Re: Suggestions for Hellcat Supercharger Bypass [Re: 72Swinger] #2229073
01/07/17 01:00 AM
01/07/17 01:00 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Which EFI controller are you using? Some have built in waste gate controls, you could probably fab one in with a waste gate valve and let the ecu handle it.
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229093
01/07/17 01:31 AM
01/07/17 01:31 AM
USA
USA
Have not bought a controller yet. The main throttle body is drive by wire so I was thinking Holley Dominator. Talked to EFI source today they are building one for the Hellcat but who knows how long it will take.
I am in over my head here a little but want to learn. I have been thinking of ways to gut the bypass valve and make it work with a vacuum. Time to do some hot rodding on this.
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229099
01/07/17 01:41 AM
01/07/17 01:41 AM
USA
USA
Had another thought. If this were to be converted to a vacuum unit, it would function no different than a magnuson, whipple, etc. The mopar plug and play kit could be tuned to work with this engine.
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229157
01/07/17 03:59 AM
01/07/17 03:59 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Or get the 4.5 Whipple that bolts to the Hellcat engines.
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229182
01/07/17 09:52 AM
01/07/17 09:52 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Are you keeping the factory EFI system? I know a guy who's tuning them now and getting noticeable gains over stock. He started out doing the 5.2/5.9 magnum stuff in Dakotas using SCT, but is now tuning all the hemi stuff as well as viper v10 stuff.
Flyinryan performance. Look him up on FB or his website.
**Photobucket sucks**
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229243
01/07/17 12:32 PM
01/07/17 12:32 PM
USA
USA
Already have the Hellcat blower, and the Whipple uses the stock hellcat bypass.
As far as EFI, don't know yet. The EFI source sounds good, as well as Mopar's new plug and play if I can get it to work with this engine/Blower
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229253
01/07/17 12:46 PM
01/07/17 12:46 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I wonder if an oil pressure sending unit would work, or something along those lines. 0 pressure and below it sends 12v to a relay which then energizes the bypass and opens. Anything above 0 and it cuts power closing the bypass. Super simplified explanation but that'd be my angle
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229374
01/07/17 03:12 PM
01/07/17 03:12 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I would try to get a vacuum operated supercharger bypass valve and piece the two together
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229388
01/07/17 03:36 PM
01/07/17 03:36 PM
USA
USA
I THINK that a vacuum retrofit would be the best ticket as of now. After looking at the electronic bypass it looks like it could be gutted and a vacuum unit bolted on.
Lots of hurdles when doing this swap on the cheap lol!
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229872
01/08/17 03:11 AM
01/08/17 03:11 AM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I wonder if the EFIsource box maintains some outputs that the megasquirt has. IF it did it should be fairly straight forward to have it open and close based on the MAP sensor. As long as the voltages are known.
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229934
01/08/17 12:10 PM
01/08/17 12:10 PM
Southern Michigan
mike_coates Offline
mike_coates  Offline
Southern Michigan
Why are you wanting to get rid of the electronic bypass?
If it is for performance gains, but still be streetable, you would be better off to keep it and get a tune to achieve what you want.
The electronic bypass is much better from an overall standpoint than the vacuum bypass. The vacuum bypass is like a rotary dial phone vs. an I phone.
If you don't get the vacuum set up right or have a problem with it, you can cook you blower. The electronic is fail to open while the vacuum fails to close.
'70 Swinger 340
'91 Dakota
'72 Challenger
'05 Ram
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229938
01/08/17 12:13 PM
01/08/17 12:13 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The Electronic bypass is hard to manage without the proper computer, and since hellcat swaps are not just real common yet I am not sure who has the ability to run it properly.
I do know there was a shop out of a Florida that did a Hellcat swap on a 60s B body and was using Holley EFI. I saw this in the G3 Hemi Swap group on Facebook.
68 Barracuda Formula S 340
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229963
01/08/17 12:52 PM
01/08/17 12:52 PM
USA
USA
Thanks for the info guys- I want to get rid of the electric bypass because of the complexity in has with it, especially for us as we are learning as we go. The way I see it, if you can get rid of that part there is no difference between a Hellcat with a vacuum bypass or a 6.4 hemi with a supercharger and vacuum bypass.
There is lots of tuning info for the supercharged 6.4's.
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2229965
01/08/17 12:53 PM
01/08/17 12:53 PM
USA
USA
One last thing I have learned- the bypass is actually the only thing that changes between the 500 hp black key and the 700 red key. Just thought I would share.
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2230174
01/08/17 06:10 PM
01/08/17 06:10 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I would ask this question on the MS3 forum (ms3efi.com). I think you would get the best drive ability with the electronic throttle body vs. a vacuum motor with no feedback to the computer. Do you know if the OE bypass is a stepper motor or full open/full close kind of deal?
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2232214
01/11/17 12:04 PM
01/11/17 12:04 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Why not just block the bypass off and let it act like the rest of the blowers out there?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Suggestions for Hellcat Supercharger Bypass [Re: hudsonhornet7x] #2232256
01/11/17 01:26 PM
01/11/17 01:26 PM
CJD AUTOMOTIVE Offline
I would stay with the electronic valve and use the Holley Dominator. You can easily configure an I/O based on MAP to open and close the valve.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Suggestions for Hellcat Supercharger Bypass [Re: AlexP] #2232583
01/12/17 12:15 AM
01/12/17 12:15 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
It causes them to overheat when you have little throttle opening
