OEM Pitman Arm Variations 1962-72 #2226447
01/03/17 05:37 PM
01/03/17 05:37 PM
Torq37 Offline OP
Torq37  Offline OP
Seeing how one pitman arm is listed by Proforged and others as fitting 1962 thru 72 B bodies I thought the OEM arms were all identical. Apparently not the case because the Proforged 103-10030 arm that I bought as a replacement for a ‘68 has a different dogleg than the original. It appears functionally the same as OEM because the clocking from the spline to drag link end is the same and the effective length equal but the dogleg is obviously different.
I assume the Proforged piece is an exact replacement for certain B bodies but which ones? And why the difference in dogleg, was this for clearance on certain models?
Re: OEM Pitman Arm Variations 1962-72 [Re: Torq37] #2226579
01/03/17 09:08 PM
01/03/17 09:08 PM
I don't have an answer but would it be possible for you to post some pics (somebody will know).
Re: OEM Pitman Arm Variations 1962-72 [Re: RapidRobert] #2226604
01/03/17 09:32 PM
01/03/17 09:32 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
N.O.S. 1962 O.E.M. original,with the part number it fits earlier than 62.
Re: OEM Pitman Arm Variations 1962-72 [Re: RapidRobert] #2227478
01/04/17 11:46 PM
01/04/17 11:46 PM
Torq37 Offline OP
Torq37  Offline OP
Unfortunately I didn’t take any pictures before putting the old one back on. For now I have the steering linkage loosely assembled until warmer weather. The original arm is almost straight as viewed from the top just like the picture that 62Max posted
The Proforged arm has a considerable hook or dogleg when viewed from the top but as I mentioned the relationship of the spline clocking to the end of the arm does appear the same as OEM so the effective geometry would appear to be the same. Also the Proforged arm has the part number cast into the arm so I know I have the correct arm....or at least as correct as Proforged makes it.
Re: OEM Pitman Arm Variations 1962-72 [Re: Torq37] #2228904
01/06/17 09:33 PM
01/06/17 09:33 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
Original part # supercedes several times:1858017, 2275458, 2835746, 2835880 & 3004811
"Long Live Mopars"
