1971 Dart Rear rear wheel/tire combo with shackle offset kit #2228491
01/06/17 10:40 AM
01/06/17 10:40 AM
Commerce, Michigan
EasyG Offline OP
EasyG  Offline OP
Commerce, Michigan
I am sure this has been discussed numerous times, but I have a 1971 Swinger that I am going to be installing a rear spring offset shackle kit on. I am looking for help with rear wheel size and offset along with the maximum "safe" tire size I will be able to fit without any other mods to the wheel wells or quarter panel. Thanks!
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228503
01/06/17 11:27 AM
01/06/17 11:27 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I had a 70 that I ran a 9x28 slick with that setup. I don't remember the wheel ofset but I know it had to be right on.
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228521
01/06/17 11:49 AM
01/06/17 11:49 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Radial verses bias matters, make sure to keep the cross section or section width of the tire in mind when figuring.
Careful, your character's showing!
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228524
01/06/17 11:58 AM
01/06/17 11:58 AM
Commerce, Michigan
EasyG Offline OP
EasyG  Offline OP
Commerce, Michigan
Will be using a drag radial for sure.
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228528
01/06/17 12:21 PM
01/06/17 12:21 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I had 4.5" bolt circle drilled into the stock small pattern flange, and found my stock 4x4 79 warlock 15x8 slots to fit pretty well. Can't recall tires as I had tried a few diff. sizes.
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228534
01/06/17 12:35 PM
01/06/17 12:35 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
What shackle kit? The 1/2" Dr Diff kit or the 3" relocation kit where you move the springs into the frame?
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228544
01/06/17 12:52 PM
01/06/17 12:52 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have been down here before i did the Mopar 3/4 kit and move the rear back 1 in and was able to fit a 275 60 15 drag radial. They may have fit if I didn't move rear back but frt wheel well was close. After that I did the min tub kit. In my opinion I wish I just did the mini tub since u have to weld and move axle perches might as well weld in frt and rear hangers. U can always move tubs at a later date.
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228560
01/06/17 01:22 PM
01/06/17 01:22 PM
Sac, CA
mopowers Online confused
mopowers  Online Confused
Sac, CA
With the Mopar "3/4 inch" offset kit (actually closer to 1/2"), you should be able to fit a 275/60/15. The BS I ended up with in my 68 Dart was 4.75", and didn't have to trim anything, though most folks say 4.5" is ideal. You'll have to measure yours to be sure. Not sure how much different 70-up wheel wells are.
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228566
01/06/17 01:35 PM
01/06/17 01:35 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I had 15x8 with 7 backspace or 6.5
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228613
01/06/17 02:43 PM
01/06/17 02:43 PM
Commerce, Michigan
EasyG Offline OP
EasyG  Offline OP
Commerce, Michigan
Planning on using the Dr. Diff offset kit.
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228630
01/06/17 03:03 PM
01/06/17 03:03 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
With that u still have to weld perches.
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228642
01/06/17 03:13 PM
01/06/17 03:13 PM
Commerce, Michigan
EasyG Offline OP
EasyG  Offline OP
Commerce, Michigan
ok, cool.. maybe it would just be worth the extra effort to do the weld in relocation kit.
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228648
01/06/17 03:19 PM
01/06/17 03:19 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The 1/2" kit will put the outer edge of the springs in line with the inner wheel well lip. It lets you fit the widest tire possible in the stock wheel wells. The 3" kit doesn't accomplish anything more unless you mini tub the car. Mini tubbing will let you run a tire all the way in to the frame. It just depends on what you want to do. The 1/2" kit is definitely the easier modification. The spring perches will still have to be moved in 1/2" per side. Stock A-body perch centers are 43". You'll need your perches at 42" centers.
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228652
01/06/17 03:26 PM
01/06/17 03:26 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
True on the 3in kit but if you do it and want at a later date all you need to do is the tubs. I had mine all apart cut the perches etc for the 3/4 kit and 3 years later I took all apart for th 3in kit
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228659
01/06/17 03:37 PM
01/06/17 03:37 PM
mopar346 Offline
mopar346  Offline
The 3 inch kit requires cutting the frame rails and is not easily undone, the 3/4 kit is a few hours to change back and no lasting effect.
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: mopowers] #2228660
01/06/17 03:39 PM
01/06/17 03:39 PM
mopar346 Offline
mopar346  Offline
What width was the rim?
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228671
01/06/17 04:10 PM
01/06/17 04:10 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I am just letting you guys know what happened to me. The 3/4 kit is easy and when I was done I thought I would never be back again. A couple years later back in it lol.
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: Scamp408] #2228681
01/06/17 04:21 PM
01/06/17 04:21 PM
mopar346 Offline
mopar346  Offline
And good information, it really depends on the end use and how far you plan to go. My GTS is mini-tubbed and my Swinger is stock. My brother is doing a 67 notch for a guy and came to look at mine because he was thinking of going the mini-tub route, when I pointed out things like cutting the frame and what you have to do with the trunk hinge supports they abandon the idea. I think the relocation kit will serve the purpose for that build cause it is for a 60+ year old man that just wants a fatter tire under it, 275 was his target. This thread got my attention for that reason to help them.
By the way I would love to see how you addressed the trunk hinge/spring issue cause I aint happy with how mine was done (before I got the car).
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: mopar346] #2228686
01/06/17 04:26 PM
01/06/17 04:26 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I will try to get a pic later
Re: 1971 Dart Rear rear wheel/tire combo with shackle offset kit [Re: EasyG] #2228708
01/06/17 04:56 PM
01/06/17 04:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have the 3/4" kit on my '72 Duster, running a 275/60R15 tire. I found that the front part of the spring is still pretty close to the tire's sidewall, close enough that clamps can't be added to the leaves without interference with the sidewall. It currently has stock/fairly tired springs, so the tires are fairly close to the sheetmetal; I'm changing springs over the winter to raise the rear a little and solve that.
Not sure what your springs or future plans are, but thought I'd pass the info on.
On my Duster racecar with the 3" kit & minitubs, 13x31s fit fine, though the openings are trimmed back at front & rear, which you may not want to do on your car.
You can measure out from the center register of your axle flange to wheel opening to determine max tire OD, but allow for suspension movement (compression).
