Re: Front tire hight
[Re: gman]
#2228639
01/06/17 03:10 PM
01/06/17 03:10 PM
Posts: 11,639 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Smaller tire = quicker reaction time and slower ET.
[Re: Cab_Burge]
#2228693
01/06/17 04:32 PM
01/06/17 04:32 PM
Posts: 1,113 Usa
A39Coronet
Usa
Foot brake car with sportsman tree as tall as possible so you can leave sooner I have ben known to let it roll in more than the other guys also This is a fairly common saying with the older guys I race with...But it depends ENTIRELY how you hit the tree. If you're leaving on the bottom bulb, you're RT is what it is...If youre bottom bulb racing, I don't know how you could leave "sooner" and still react to the bottom. Going down to a 27" helped me slightly... Probably going to go even more next time I need fronts so I don't have to leave at 3k to go .00X
[Re: A39Coronet]
#2228709
01/06/17 04:56 PM
01/06/17 04:56 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
Foot brake car with sportsman tree as tall as possible so you can leave sooner I have ben known to let it roll in more than the other guys also This is a fairly common saying with the older guys I race with...But it depends ENTIRELY how you hit the tree. If you're leaving on the bottom bulb, you're RT is what it is...If youre bottom bulb racing, I don't know how you could leave "sooner" and still react to the bottom. Going down to a 27" helped me slightly... Probably going to go even more next time I need fronts so I don't have to leave at 3k to go .00X With regular bulbs(not LED) back in the day I could see the bottom ( any or all of them one at a time)start to glow, get brighter and then start to go out. When I would ask some of the other racers about when they would leave they had no idea about seeing the bulbs start to glow, get brightest and then start to go out As far as having several different size front tires mounted on spare rims in the trailer is a good thing Not all tracks have the same and equal roll out, even on both sides of the track
