440 engine kits #2228128
01/05/17 09:29 PM
01/05/17 09:29 PM
USA
Lawn Monkey Offline OP
USA
Who sells a decent 440 engine kit, Heads,intake, pistons, gaskets?
And what's it going to cost me scope
Re: 440 engine kits [Re: Lawn Monkey] #2228134
01/05/17 09:33 PM
01/05/17 09:33 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I've had good luck with 440Source.
Re: 440 engine kits [Re: Lawn Monkey] #2228150
01/05/17 09:51 PM
01/05/17 09:51 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
That will vary depending on your goals:
Daily driver?
Street Strip - mild? Wild?
Race only?
Race an occasional street??
HP and the related ET/MPH goals in you have them in mind?
Re: 440 engine kits [Re: cudadoug] #2228171
01/05/17 10:20 PM
01/05/17 10:20 PM
USA
USA
Daily driver?
Race only?
Can I pick 2 ,Daily driver?
Street Strip - mild? Wild? I wan fry the tires a high 12 would be fine.
Re: 440 engine kits [Re: topside] #2228326
01/06/17 12:37 AM
01/06/17 12:37 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
After three sets of cracked cylinder heads, a fabricated oil pan that didn't fit, and a fabricated timing chain cover that was 1/4" too shallow, I've come to realize you get what you pay for with them. I'll trust them for water necks and non-440 source made parts, but never with heads or rotating assemblies again.
Ohio Crankshaft makes Mopar stroker kits and we can benefit from the advancements they make with their GM market. The customer service was outstanding.
Heads, intakes, and gaskets are likely cheapest (and best return policy if there's an issue) with Jegs and Summit.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 440 engine kits [Re: Lawn Monkey] #2228354
01/06/17 01:22 AM
01/06/17 01:22 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You need to get wwith an eng builder that will work with you as you can source parts from a few places and you want to work with someone who knows the business. Myself I use a 440Source stroker kit crank , rods , pistons and the small parts. Built it myself and its been great for almost 6 years so far. So you see you will get many different opinions. I dont use their heads as I bought Indy EZ heads from Dwayne Porter. So your best bet is to find a good eng person to work with you and I take it to build your eng unless you have done that work. If you have a local person to work with thats good. I bought my heads from Dwayne Porter but I am sure he would build your eng for you also as he sells alot of the parts and knows the best parts to use.
Get with a builder you trust and work with them as you will get alot of different opinions on here and most will be good opinions but we may have your head spinning all over.
Do you have a good local machine shop you can work with ? Unless you can build your own engines I would get with a good builder you can trust and work with them. Ron
Re: 440 engine kits [Re: Lawn Monkey] #2228448
01/06/17 05:01 AM
01/06/17 05:01 AM
Daily driver?
Race only?
Your goals are easily doable in todays market, what year, body style, tranny and rear end and rear gear ratio do you have now?
The reason I'm asking about these is the larger C.I. stroker pump gas motors with a set of Eddy RPM heads and a decent size(850CFM+) carb. will be a real tire fryer and may be hard to hook up at the track on small street tires work shruggy
Mid to high 12.s in the 1/4 are doable on the proper size street tires thumbs
Re: 440 engine kits [Re: Cab_Burge] #2236260
01/17/17 08:43 PM
01/17/17 08:43 PM
USA
USA
It's a full body Challenger , hemi 4 speed and a 4.10 dana,15x7 rallys eventually I want to ditch the 4.10 for a 3.54 gear. Not up on strokers , I want to build this engine once so probably just a simple 440 for reliability factor will do. thanks appreciate the replies up
