Re: is the BFG radial T/A the only 15" tire left?
[Re: furious70]
#2224826
01/01/17 03:51 PM
01/01/17 03:51 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I might have the room, but don't most people really dislike that much tire up front with stock suspension and steering? Thought I've heard people complain that the car will grab and pull with that much tire up front. If you have manual steering, your arms aren't going to like a wider tire.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#2224835
01/01/17 04:03 PM
01/01/17 04:03 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I might have the room, but don't most people really dislike that much tire up front with stock suspension and steering? Thought I've heard people complain that the car will grab and pull with that much tire up front. If you have manual steering, your arms aren't going to like a wider tire. Hmm, when my 64 300 lost it's power steering pump I drove it without power assist for years. I was running P245/60R15's in the front, 9.6" wide at teh tread. Steering a no assist power steering setup is harder than a manual steering setup. Stock power steering ratio is 15.7:1, but without the larger steering wheel or alignment specs a dedicated manual steering car has. It was a stick too. Never had a problem driving it and I was driving it in San Diego at the time. Guess it's all in the mindset. My Cuda has manual steering, but it the 24:1 setup, yay, not. It'll, eventually, get a 16:1 setup.
[Re: TC@HP2]
#2224838
01/01/17 04:06 PM
01/01/17 04:06 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
I don't know.... Cooper tires are still made in the USA, although they do own tire companies in the UK and China. I know opinions vary on whether they make any UHP tires, but it just seems wrong to put foreign tires on an American classic. Even Michelin tires make my skin crawl.
My goof. I thought they were owned by the Brits. I guess it is the other way around, which actually is pretty cool. Avon makes the only remaining Z rated UHP 15" tires out there for handling applications. Looks like Cooper also owns MT, which explains why the MT ST and Cooper Cobra look nearly identical. They also own 11% of Kumho and 51% of Chengshan. For other fans out there, Cooper also makes Dean, Futura, Arizonian, Mastercraft, Starfire, Hercules, and Sears Gaurdsmans. Far out man! They also make Mastercraft tires.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: mopargem]
#2224841
01/01/17 04:08 PM
01/01/17 04:08 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
It's pretty well known now that with some of the BFG radial ta's the white letter turns brown so they need to be boycotted until the problem is solved. One of my tires letters looks awfull brown and couple others are ivory. Yep, I'm in the same boat. None of the various solutions suggested here on Moparts have corrected the situation. It's definitely in the compound. So, if you do buy BFG, I'd recommend buying local and understanding the warranty. Make sure they will replace them, if they turn brown. That way, you're covered, even though it's a pain to have to get it done. I ordered mine from Amazon using points and there's really no way to get them warrantied, especially with shipping costs. Keep that in mind on any tire you order online. I'm not saying don't order online, just understand the ramifications if there's an issue.
[Re: Dixie]
#2224919
01/01/17 05:20 PM
01/01/17 05:20 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Was in a local tire shop here last week... They've been around for many years... Talked about the T/A letter-bleeding issue... Said they've never seen it...
[Re: RSNOMO]
#2225081
01/01/17 09:30 PM
01/01/17 09:30 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Was in a local tire shop here last week... They've been around for many years... Talked about the T/A letter-bleeding issue... Said they've never seen it... when was the last time they sold one...... i'm sure it's a popular tire for Joe average.....
[Re: Airgrabber]
#2225167
01/01/17 11:36 PM
01/01/17 11:36 PM
Posts: 3,379 KY USA
mopargem
KY USA
Here's mine on the charger. BF Goodrich should call them Raised Brown Letter tires.
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: Supercuda]
#2225449
01/02/17 12:10 PM
01/02/17 12:10 PM
Posts: 2,260 IL
furious70
IL
I might have the room, but don't most people really dislike that much tire up front with stock suspension and steering? Thought I've heard people complain that the car will grab and pull with that much tire up front. If you have manual steering, your arms aren't going to like a wider tire. Hmm, when my 64 300 lost it's power steering pump I drove it without power assist for years. I was running P245/60R15's in the front, 9.6" wide at teh tread. Steering a no assist power steering setup is harder than a manual steering setup. Stock power steering ratio is 15.7:1, but without the larger steering wheel or alignment specs a dedicated manual steering car has. It was a stick too. Never had a problem driving it and I was driving it in San Diego at the time. Guess it's all in the mindset. My Cuda has manual steering, but it the 24:1 setup, yay, not. It'll, eventually, get a 16:1 setup. With a big block, a/c, and a twin turbo setup hanging out up front, I prefer the power steering turning the 235's
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: Airgrabber]
#2225497
01/02/17 01:13 PM
01/02/17 01:13 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Feets, what brand and size do you recommend to replace a 275/60-15 and 235/70-15? The hot rod had tires in those sizes. when it came time to replace them I used Nitto NT555 in 245/45-18 and 295/45-18.
[Re: furious70]
#2225524
01/02/17 01:40 PM
01/02/17 01:40 PM
Posts: 2,260 IL
furious70
IL
hey - post a good pic of the hot rod side profile with those rims, been way too long since I've seen it - I want to see the sidewalls tirerack only shows these when I search for a set of those sizes http://www.tirerack.com/tires/TireSearch...rearDiameter=18
[Re: furious70]
#2227081
01/04/17 02:02 PM
01/04/17 02:02 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
Maxxis MA-S1 Update:
I downloaded their tire brochure and it gave information on most of their tires (off road to competition). Since the UTQG rating is based on each tire manufacturer, I wanted to review their ratings to see where the MA-S1 rated. They show the following UTQG ratings:
AC-1 Competition tires as 100
MA-S1 tires as 360 (apx. 30k miles) SUV/LT All Season Performance
MA-P1 tires as 380-440 (40-50k,) Performance Touring
MA-1 tires are 480 (60k miles) Grand Touring
CUV tires are 520 (60k miles) Crossover Premium Touring
MA-T1 tires are 560-720 (60-100k miles). Premium Touring
So it looks like from using Maxxis's own UTQG ratings, the MA-S1 tires may be "stickier" than most of the passenger type tires that they produce.
The MA-S1 tires are a black wall SUV/Light Truck All Season Performance Tire and their P295/50R15, P275/60R15, P255/60R15, and their P245/60R15 are all rated at 44psi for maximum pressure and have the H speed rating (130mph).
I just wanted to throw this out there for reference.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: fc7_plumcrazy]
#2230523
01/09/17 12:31 AM
01/09/17 12:31 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
I am glad to love driving my Goodyear Polyglas GT tires a lot.
Carsten I have them and love the look but care not for the stiff ride. Perhaps with Coker coming out with a Firestone Wide Oval looking radial tire, hopefully we will see same for Goodyear Poly's one day. Being in Germany and with the autobahn and all, with many areas of no speed limits, brought to mind an old question of mine. Does anyone know if there is a speed rating on these reproduction bias ply RWL Goodyears such as on modern tires.
[Re: furious70]
#2231162
01/09/17 10:45 PM
01/09/17 10:45 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I remember when a shaved TA was a track tire.
Have a great day Iowan
"obsolete is neat"
[Re: furious70]
#2231350
01/10/17 01:51 AM
01/10/17 01:51 AM
Posts: 2,260 IL
furious70
IL
not sure I like the smaller tire on the bigger plymouth, this is a 235/55/18 from my 2012 Charger, 28" just like the 235/70/15
[Re: furious70]
#2231573
01/10/17 01:29 PM
01/10/17 01:29 PM
feets
Senior Management
Senior Management
Irving, TX
not sure I like the smaller tire on the bigger plymouth, this is a 235/55/18 from my 2012 Charger, 28" just like the 235/70/15 A big part of it is the wheel. If your wheel doesn't compliment the car them it'll always look bad. Think about the factory setup with whitewalls. The whitewall was closer to the bead than the tread. It gave the impression of a larger diameter wheel. Get the proper wheel and you can bring back some of that look. It'll be okay. On your C barge I'd look for a 29" tire. I run a 29.5" tire on the Imp.
