69 318 with 302 heads? #2225952
01/02/17 11:08 PM
01/02/17 11:08 PM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Hi Guys, I have a 1969 Dart GT 318 with 70K original miles on it. I put a 68 340 intake on it with a 625 AFB. I also have dual exhaust and a Mopar Performance electronic distributor installed. I want to get some more HP out of it, with more low end torque. I picked up a set of 302 heads today. My question is should I put bigger valves in the heads and what cam should I use. I don't want to do anything to the short block, just bolt on some more performance. Any suggestions would be appreciated.
Thanks Scott.
1966 Coronet 440 conv. original Mauve metallic, with white top and interior. 1971 360, J heads, 625 AFB, 340 cam, intake, and manifolds. With 3.23 SureGrip.
1969 Dart GT: B5 Blue, White top, 318, With A/C
Re: 69 318 with 302 heads? [Re: ScottG] #2225958
01/02/17 11:18 PM
01/02/17 11:18 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would say, that car's a beauty, don't go too nuts.
Re: 69 318 with 302 heads? [Re: ScottG] #2225963
01/02/17 11:23 PM
01/02/17 11:23 PM
Georgetown de usa
E
Eggman Offline
Eggman  Offline
E
Georgetown de usa
You could go with a Summit house brand cam which is ground by Elgin. They have the 6900 which is 204/214-.421/.444 on a 112 lsa or the 1789 which is 216/216-.454/.454 on a 110 lsa.
Re: 69 318 with 302 heads? [Re: buildanother] #2225967
01/02/17 11:26 PM
01/02/17 11:26 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I agree, very nice.
Careful, your character's showing!
Re: 69 318 with 302 heads? [Re: ScottG] #2225969
01/02/17 11:27 PM
01/02/17 11:27 PM
Georgetown de usa
E
Eggman Offline
Eggman  Offline
E
Georgetown de usa
The 6900 with stock valves,the 1789 with modded heads.
Re: 69 318 with 302 heads? [Re: ScottG] #2225992
01/02/17 11:52 PM
01/02/17 11:52 PM
when you get the cyl psi finalized (heads/cam/cam advanced) I would dial in the dist subsystems for a significant gain
Re: 69 318 with 302 heads? [Re: Eggman] #2226000
01/02/17 11:59 PM
01/02/17 11:59 PM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Don't worry I am not going to go nuts. LOL I still have all of the parts to put it back to stock if I would want to. I just want to see if I can get a little more out of it. Thanks for your replies.
Re: 69 318 with 302 heads? [Re: ScottG] #2226075
01/03/17 01:11 AM
01/03/17 01:11 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
302 heads aren't worth putting money into. Magnum heads would have been a good bang for the buck.
Are the 302 heads better than the 69 heads? Yep, but not enough better stock for stock to warrant the costs of the gaskets to swap them and putting more money into them to improve performance is worse costwise.
A cam swap would perk either set of heads up though. I like the 340 cam in a street 318 myself.
Don't be the exception.
Re: 69 318 with 302 heads? [Re: ScottG] #2226136
01/03/17 03:04 AM
01/03/17 03:04 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Unfortunately there isn't any "cheap" way into a performance head upgrade on a LA 318.
The 302 wouldn't be a bad way to go if the heads currently on the motor needed overhauling anyway, but if the current heads have no issues, it's going to be a pretty big expense for minimal gains(unless the 302 heads have a fair amount of work done to them=$$$).
The valve springs on 318's are really quite low pressure, so I would keep the cam selection on the very mild side unless springs are part of the plan.
A nice little cam swap in those motors that can be done while still using the OE springs is a 360 2bbl cam. It's quite a bit bigger than a 318 cam, but works with the OE springs, and the lift is low enough not to cause any retainer to seal issues.
Re: 69 318 with 302 heads? [Re: ScottG] #2226362
01/03/17 03:33 PM
01/03/17 03:33 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The 302 heads actually flow worse than the old open chamber 318 heads or any other 318 head actually. They do have more swirl and closed chambers for a little more compression but the flow will probably make more power in the end so you need to do some upgrades in the flow department or you will not be happy. The magnum heads are better flow, swirl and compression and can easily be disquised, the original valve covers still bolt on, the ex manifolds bolt on and you can redrill the intake bolt holes to keep your original intake. The 1.6 rockers will make it seem as though your cam is bigger to boot. If you just have to run the 302 head put in 360 valves and touch up the ports, bowls and PR pinch a little and run the 360 2bbl cam fast mentioned, grind down the sharp point in the middle of the chamber and unless you run a steel shim head gasket you will lose any compression you gain from the smaller chambers and then some. The only place I can find steel shim headgaskets is in the MrGasket MLS head gasket, I buy one gasket pop the rivets out and the two outer layers become two individual steel shim head gaskets.
Re: 69 318 with 302 heads? [Re: HotRodDave] #2226590
01/03/17 09:18 PM
01/03/17 09:18 PM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Thanks for the info guys. I knew the heads would need to be ported when I bought them. This is something I want to try to do myself. They were only $50 and they were allready pulled from a running motor. So if I mess them up it's no big deal. I don't want to touch the original heads. I have read some articles that if these heads are ported right they can flow really good. So It is a challenge to me to see if I can make them work. I am looking for low end torque with quick responce, should I leave the stock valves or put the 1.88-1.60 in it? I also read to shave .020 off them to keep the compression up. Not trying to do it the cheapest way, this is just a little project I have wanted to try.
Thanks again
Scott
Re: 69 318 with 302 heads? [Re: ScottG] #2226691
01/03/17 11:01 PM
01/03/17 11:01 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I like to put in the bigger valves so I can shape the bowls better, get a better VJ as well as they can flow more.
.020 won't make much difference, probably at least .030 or .040 or more if you end up with a thicker head gasket than the stock steel shims.
Re: 69 318 with 302 heads? [Re: ScottG] #2226695
01/03/17 11:06 PM
01/03/17 11:06 PM
If you Googled em I think some good reading would come up. A skim cut would ensure the decks are flat & iirc some 1.88's are a good plan. I have a set I purchased for either 50 or 75 I forget which about 15 years ago. I wanna build a tight quench 318 for a mileage DD. skim cut/new guides/new valves would be completely gone thru (use em & get your moneys' worth out of em). I would home port em especially as I did not realize they were real dogs as is.
