Anyone have an old CRANE cam catalog? #2225813
01/02/17 07:54 PM
01/02/17 07:54 PM
Dallas, Texas
FC7cuda Offline OP
FC7cuda  Offline OP
Dallas, Texas
Need help identifying the specs for this cam please.
Tom
68 Charger
70 Cuda
Re: Anyone have an old CRANE cam catalog? [Re: FC7cuda] #2225851
01/02/17 08:51 PM
01/02/17 08:51 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It's not in my 2010 catalog, but going by the numbers it should be:
solid flat tappet, 275@.050, .400 lobe lift, 104lsa.
Re: Anyone have an old CRANE cam catalog? [Re: FC7cuda] #2225938
01/02/17 10:47 PM
01/02/17 10:47 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Those specs are very similar to the old Mini-Express .654 (with 1.5 rockers, so .436 lobe lift), measured at 278@.050, 107 lsa, and requires 1.00" mushroom lifters. Pretty ballsy specs for a .904" lifter... work
Re: Anyone have an old CRANE cam catalog? [Re: FC7cuda] #2226027
01/03/17 12:34 AM
01/03/17 12:34 AM
hickory nc USA
skyhawk61 Offline
skyhawk61  Offline
hickory nc USA
Cam number is not listed in my 87-88 Crane Master Catalog. Might be older. dc
Re: Anyone have an old CRANE cam catalog? [Re: skyhawk61] #2226299
01/03/17 02:07 PM
01/03/17 02:07 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Too bad Chase Knight retired.
He used to pop onto Moparts and answer Crane questions.
Re: Anyone have an old CRANE cam catalog? [Re: FC7cuda] #2226524
01/03/17 07:43 PM
01/03/17 07:43 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
You can contact Crane and they will give you the info on the cam.
Nautilus Racing-
Re: Anyone have an old CRANE cam catalog? [Re: FC7cuda] #2226570
01/03/17 09:00 PM
01/03/17 09:00 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Tom
In my 78 and 79 catalogue I'm showing a F275/400-8 cam for 273-340-360 and 67-79 318 LA, if that comes close to being what your cam is made to fit. Crane says 275 degrees @.050, 316-316 degrees advertised, 108 centerline on this one though yours appears to be ground on a 104 centerline, .028 hot on intake, .030 hot on exhaust, 0.600 gross valve lift on intake and 0.600 gross valve lift on exhaust also.
Re: Anyone have an old CRANE cam catalog? [Re: FC7cuda] #2226656
01/03/17 10:32 PM
01/03/17 10:32 PM
Dallas, Texas
FC7cuda Offline OP
FC7cuda  Offline OP
Dallas, Texas
Thanks everyone, I'll contact Crane to be sure, but it sounds like John hit the nail!
Tom
68 Charger
70 Cuda
Re: Anyone have an old CRANE cam catalog? [Re: FC7cuda] #2226660
01/03/17 10:34 PM
01/03/17 10:34 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Tom
John and Fast, to be correct. wave
Re: Anyone have an old CRANE cam catalog? [Re: Sport440] #2226666
01/03/17 10:38 PM
01/03/17 10:38 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Tom
