340 Six Pack correct throttle/kickdown spring positions #2225371
01/02/17 07:12 AM
01/02/17 07:12 AM
USA
FM3AAR Offline OP
FM3AAR  Offline OP
USA
Hi all,
In the picture below (340 Six Pack/auto), are the spring ends in the correct positions on the throttle shaft or should they be reversed? I see them both ways on the internet and I am sure they will function either way, just curious as to the correct positions. Thanks
Re: 340 Six Pack correct throttle/kickdown spring positions [Re: FM3AAR] #2225491
01/02/17 12:07 PM
01/02/17 12:07 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Based on several factors I'd say the spring as shown in your photo is backwards.
1) The natural tendency of the kick down (green) spring is to be centered and not bind with anything, reversing the order will allow this
2) The throttle return (orange) spring has a long straight section that allows it to ride in close proximity to the kick down plate without interfering or binding
3) See attached drawing from the parts manual for 1970
Now, that all said is it possible that some line worker delivered some, or many, not per the engineering design, absolutely, but I'd stick to the drawing.
Re: 340 Six Pack correct throttle/kickdown spring positions [Re: FM3AAR] #2225586
01/02/17 01:47 PM
01/02/17 01:47 PM
USA
FM3AAR Offline OP
FM3AAR  Offline OP
USA
I was thinking the same thing also. I noticed that the kickdown spring was rubbing against the kickdown plate when I set mine up like in the first picture. Otherwise the picture I posted shows what appears to be a very original/correct 340 Six Pack so I was wondering.
Thanks for the reply and the excellent diagram. thumbs
Re: 340 Six Pack correct throttle/kickdown spring positions [Re: FM3AAR] #2225675
01/02/17 03:44 PM
01/02/17 03:44 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
The image is actually a 340 4bbl, but the kick down will be identical for a 6 bbl.
Re: 340 Six Pack correct throttle/kickdown spring positions [Re: AAR#2] #2225684
01/02/17 03:52 PM
01/02/17 03:52 PM
USA
FM3AAR Offline OP
FM3AAR  Offline OP
USA
Sounds good. I went out and corrected the springs on mine already.
I notice the throttle spring is now more in line (square) to the throttle shaft. thumbs
Re: 340 Six Pack correct throttle/kickdown spring positions [Re: FM3AAR] #2225697
01/02/17 04:07 PM
01/02/17 04:07 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
4-speed application;
Re: 340 Six Pack correct throttle/kickdown spring positions [Re: Alaskan_TA] #2225711
01/02/17 04:27 PM
01/02/17 04:27 PM
USA
FM3AAR Offline OP
FM3AAR  Offline OP
USA
Thanks Barry. thumbs
