IT might seem like a dumb question but I cant remember running across it. I am using a dash from a Dart Custom in my GTS due to the GTS being hacked over the years for racing. I am reusing the harness from the Custom, the door jamb switch wires on the custom are the female side of a blade connector, the GTS' harness has the male side of a bullet connector. In and of itself no biggy since I have all the harnesses and of course plenty of terminals. My guess is that the difference is due to the custom have a lighting group and the GTS not. I am assuming the Custom took the 2 blade switch as opposed to the single bullet style switch that the GTS has. Am I correct?
Thanks in advance, Kevin
