Battery Cables Repops #222408
02/12/09 06:52 PM
02/12/09 06:52 PM
3
340dart4spd Offline OP
Parts Problem
Parts Problem
3
Re: Battery Cables Repops [Re: 340dart4spd ] #222409
02/12/09 06:56 PM
02/12/09 06:56 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
The negative is totally wrong for a 68-69.They use a single cable only.
Re: Battery Cables Repops [Re: 340dart4spd ] #222410
02/12/09 07:15 PM
02/12/09 07:15 PM
Retired now in Tennessee
Chi_Town_Runner Offline
Not sure how "EXACT" you neeed to be.
Check here A & M Hightechauto. He posts here on a regular basis.
Look under "Electrical" then under Battery Cables.
Part #BC-70 for Positive cable
Part #MD-778 for Neg cable.
I've been told "not exact" but close.
He also has Concourse correct if you need.
Hope this helps.
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Battery Cables Repops [Re: 340dart4spd ] #222411
02/12/09 07:31 PM
02/12/09 07:31 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
are these any where close 68-70 cables
Depends on how accurate you want the final product to be. As mentioned, and depending on the intended year - the negative is completely wrong primiarily due to the extra lead on the negative cable.
Will they work, ? I can't answer .
My question would be, how is the splicing of the wiring done. I have something similar but I can't touch that price.
Re: Battery Cables Repops [Re: formula_s] #222412
02/12/09 08:08 PM
02/12/09 08:08 PM
3
Parts Problem
Parts Problem
3
I am looking for a 70 383 /440 aplication
Re: Battery Cables Repops [Re: 340dart4spd ] #222413
02/13/09 08:10 PM
02/13/09 08:10 PM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
They look like the ones I got for my 70 383 Coronet. They are not concourse but the fit is fine. I know on what was left of my original positive cable the two wires were a different shades of red and the repops are both the same color. My original ends were long gone so cant tell you about those. Many guys on here know them though. In the end if you want a clean looking install with new cables they work just fine.
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
