W2 econo heads #2223855
12/31/16 03:28 AM
12/31/16 03:28 AM
jeff500 Offline OP
jeff500  Offline OP
I'm looking at buying a set of w2 econo heads and was wondering how to tell if they are the good castings or the older ones that crack.I don't have any casting #s.is there a visual check I can look for?
Re: W2 econo heads [Re: jeff500] #2223921
12/31/16 11:03 AM
12/31/16 11:03 AM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Yep. They have a rib looking area around the outside bolt holes and Mopar is raised cast. The old ones were just flat like a typical LA. I have one of both, but have never been able to post pics. If you need pics, PM me you cell # and I will text you a pic of each.
Re: W2 econo heads [Re: jeff500] #2223975
12/31/16 01:01 PM
12/31/16 01:01 PM
Socal
littleVAL Offline
littleVAL  Offline
Socal
I thought the older ones cracked from being milled to thin. That is also why newer ones have smaller combustion chambers as well. No need to cut them down.
Re: W2 econo heads [Re: littleVAL] #2224021
12/31/16 01:56 PM
12/31/16 01:56 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I found a couple of pictures of W2 heads. I found one with the ribs and one without (Econo, dual exhaust bolt pattern). Both have rocker arm pedistals.
Hope this helps for discussion.
Is there a W2 that took the standard LA rocker arm gear? If so, can you tell me which part number to look for?
Re: W2 econo heads [Re: jeff500] #2224030
12/31/16 02:12 PM
12/31/16 02:12 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The version just prior to the ones having the ribs around the head bolt holes are pretty thin in that area of the external wall.
I had a brand new one, hardly milled at all, crack wide open there during installation.
Torquing the head bolts......"snap".
I was pretty surprised how thin it was.
The only ones I would even consider would be the ones with the ribs.
Re: W2 econo heads [Re: jeff500] #2224057
12/31/16 02:52 PM
12/31/16 02:52 PM
jeff500 Offline OP
jeff500  Offline OP
The ones I'm looking at do not have the ribs by the bolt holes but they do have the metal plugs in the end of the heads.
Re: W2 econo heads [Re: jeff500] #2224065
12/31/16 03:01 PM
12/31/16 03:01 PM
So. Burlington, Vt.
So. Burlington, Vt.
I'm not a w2 guru by any means, but I believe there are at least 3 "generations" of them.
The first basically look like stock heads externally.
The second have a more smoothed over exterior, no ribs around the outer bolt holes, and iirc they have "Mopar W2" cast into them on the exhaust side of the head.
The letters are indented in, not raised.
The third has the ribs by the bolt holes, letters raised.
There might be other versions or variations within those versions as well.
Re: W2 econo heads [Re: jeff500] #2224073
12/31/16 03:10 PM
12/31/16 03:10 PM
jeff500 Offline OP
jeff500  Offline OP
I've noticed that some have the small freeze plugs in the end of the heads and some dont.was wondering what's up with that.
Re: W2 econo heads [Re: fast68plymouth] #2224074
12/31/16 03:13 PM
12/31/16 03:13 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
My W2 Econo heads cracked right by where the W2 was cast on the outside part of the head under the exhaust port. Both heads leaked water out the crack. It was a shame because they ran easy 9's in my Duster with a little port work I did and stock 2.02 valves. The heads are still leaning against the wall in my shop but after that happened I sold off 2 sets of rockers and a W2 intake that I ported.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: W2 econo heads [Re: jeff500] #2224078
12/31/16 03:16 PM
12/31/16 03:16 PM
So. Burlington, Vt.
So. Burlington, Vt.
I believe only the first gen have the core plugs, but that might also be a first gen/econo only thing.
Someone more knowledgable about them would have to clear that up.
I think the basics are:
First gen
2nd gen
3rd gen
Re: W2 econo heads [Re: jeff500] #2224162
12/31/16 05:50 PM
12/31/16 05:50 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Here is a couple of pictures...yes..early w2 had freeze plugs on them..later did not...picture of standard length and long valve econo heads..
and second picture shows ribs vs non rib w2...
Tony
70 AARCuda Vitamin C
