E body clock disassembly?? #2222960
12/29/16 08:33 PM
12/29/16 08:33 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Has anyone taken the clock on a rallye dash apart to get to the inside workings? I have everything else done on the cluster but the clock. I know there are companies out there that do it,but my funds are low. Thanks guys.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: E body clock disassembly?? [Re: stickman] #2223002
12/29/16 10:25 PM
12/29/16 10:25 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
I got it apart. Now who sells the quartz set up for it?
Re: E body clock disassembly?? [Re: stickman] #2223163
12/30/16 03:05 AM
12/30/16 03:05 AM
WA
tman Offline
tman  Offline
WA
I believe all the kits are the same by Instrument Services. Prices vary. Here is an example:
http://www.ebay.com/itm/Quartz-Conversion-Clock-Repair-Kit-R-3035-with-Instructional-DVD-/371537829782?hash=item5681615f96:g:IjwAAOSwLnlWoR~v&vxp=mtr
