Holley Carburetor Identification #2222572
12/29/16 01:36 AM
12/29/16 01:36 AM
Tennessee
Bunk Offline OP
Bunk  Offline OP
Tennessee
I have acquired a Holley mechanical secondary double pumper carb that has had the air horn milled off eliminating the identifying numbers. I was told by the seller that it was an 850 but I have since determined that it cannot be an 850 due to the smaller 1 9/16" throttle blades all the way around. The blades are numbers 172 and 173. Other than the blades I have numbers p 46 on the driver side main body and r 24 on the passenger side main body. The metering blocks have numbers 8543 on the primary and 6501 on the secondary. I have a power valve only on the primary metering block. Anyone with knowledge of Holley carbs please post what you know. I do appreciate it!
The beginning of knowledge is the fear of GOD.
Re: Holley Carburetor Identification [Re: Bunk] #2222699
12/29/16 12:05 PM
12/29/16 12:05 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Measure the ID of the venturi.
Re: Holley Carburetor Identification [Re: Bunk] #2222729
12/29/16 01:15 PM
12/29/16 01:15 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If it truly has 1-9/16" throttle bores(not 1-11/16"), and is a double pumper...... It's a 600.
As I recall, "most"(if not all) 600dp's have brass secondary throttle blades...... Although I haven't had one in my hands in several years.
If is has 1 11/16" throttle bores, then you need to know the Venturi diameter...... Unless you've been messing with them forever, in which case you can tell just by seeing the Venturi shape/size/booster config and just "know".
Re: Holley Carburetor Identification [Re: Bunk] #2222989
12/29/16 09:51 PM
12/29/16 09:51 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
if you google holley 172 and 173 blades i think you will find they are actually 1-11/16" blades, i'm going by memory so i could be wrong.
Re: Holley Carburetor Identification [Re: Bunk] #2223001
12/29/16 10:25 PM
12/29/16 10:25 PM
So. Burlington, Vt.
So. Burlington, Vt.
I think you're right.
The quick-look ID for the non-race type 1-11/16 throttle bore carbs:
650-bar type boosters, pri/sec Venturi diff size
700-bar type boosters with flared bottom, pri/sec Venturi diff size, 50cc rear pump
750-downleg boosters, all Venturi same size
800-downleg boosters, pri/sec Venturi diff size, 50cc rear pump
Re: Holley Carburetor Identification [Re: krautrock] #2223191
12/30/16 04:00 AM
12/30/16 04:00 AM
Tennessee
Bunk Offline OP
Bunk  Offline OP
Tennessee
I think you might be right too. Today I had a friend with Holley knowledge take a look at it. He says removing the rear power valve or replacing rear metering block is an old drag racers trick to allow use of even bigger secondary jets or something like that. He also said he believes the carb is an 800 cfm. ??? I got it installed and dialed in and my built 440 absolutely loves it!
Re: Holley Carburetor Identification [Re: Bunk] #2223351
12/30/16 02:12 PM
12/30/16 02:12 PM
Mark Whitener Offline
Measure the venturi. Could be an 830 as well.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Holley Carburetor Identification [Re: Bunk] #2223485
12/30/16 05:52 PM
12/30/16 05:52 PM
Tennessee
Bunk Offline OP
Bunk  Offline OP
Tennessee
I have a venier caliper but its jaws are too short. What do you use to get an accurate measurement?
Re: Holley Carburetor Identification [Re: Bunk] #2223504
12/30/16 06:16 PM
12/30/16 06:16 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
spread a paperclip till it just touches the walls, then pull it out and measure it with caliper.
Re: Holley Carburetor Identification [Re: Bunk] #2223520
12/30/16 06:40 PM
12/30/16 06:40 PM
Washington
madscientist Offline
Washington
Or a snap gauge. Those can be had pretty cheap in a complete set.
Re: Holley Carburetor Identification [Re: Hot 340] #2223528
12/30/16 06:50 PM
12/30/16 06:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
THIS.............Do it all of the time......... beer
Re: Holley Carburetor Identification [Re: Thumperdart] #2223550
12/30/16 07:10 PM
12/30/16 07:10 PM
Washington
Washington
Dam Dom, I'll gonna figure out your birthdate and send you a set of snap gauges for all the help you've given me!!!!!!!
Re: Holley Carburetor Identification [Re: madscientist] #2223573
12/30/16 07:59 PM
12/30/16 07:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I see how that looks............lol I meant I use inside calipers then a tape measure which gets ya close...........NOT a paperclip........... laugh2
Re: Holley Carburetor Identification [Re: Bunk] #2228120
01/05/17 09:23 PM
01/05/17 09:23 PM
Tennessee
Bunk Offline OP
Bunk  Offline OP
Tennessee
The carb in question has 1 3/8" venturies front and rear and 1 11/16" throttle bore diameters front and rear. Based on these measurements the carb appears to be 750 cfm. Thanks to you all!
